Question about JVC 580136 Camcorder
JVC GY-HD 110
I am having problem with my computer seeing my camera. It's JVC GY-HD110. The Tech at JVC advised me to get Adobe Premiere Pro CS3. I did. My computer still cannot see the camera. I call back the repair center guy said that I may have plugged the IEEE 1394 wire backward and I may have reverse the polarity and damaged the circuit board in Camcorder. He stated that that is common problem. I did not believe him. The connector can only go in one way. I was quick to say that this not a manufacturer defect. I said this will cost around $800.00 to replace the board. It seems that they may know about the problem and want the consumer to pay to replace the board. Even that, should that cost about $800.0?
Can you help solve this problem? AG
I have had a problem with this. The first time I was setting up the camera I too couldn't get the computer to detect the camera. The computer will detect it before any program can begin to use it. I was using the pinnacle moviebox. I find that I have to use the cord only one way out of the camera and use the same end connected to the camera everytime and the other end into the moviebox or hardline into your computer. Believe it or not, i have to press the end into the moviebox good and snug otherwise it will not detect it. I also use a filter on the cable to stop any potential interference and a good indicator next time which end belongs in the camera and which one back in the computer. Since I have done this, I haven't had any trouble.
I connect the camera via IEEE 1394 with a cable with gold connections (10 bucks at target), into the pinnacle moviebox and then backout to the computer with USB into USB 2.0 port on my pc. My PC is running XP Media Center.
Posted on Oct 09, 2008
Authorization code adobe premiere pro cs3 serial number 1132-1230-1273-2903-8483-2223
my
serial number: 1325-1313-7851-3139-7117-7170
activation number: 0727-4694-7322-7872-8141-2646-5215
i need authirization code: ? please help me....
Jan 28, 2013 | Adobe Premiere Pro CS3 Full Version for PC...
Tip
Edit flip camera files with Premiere Pro
Overview of Adobe Premiere and Flip Camcorder:
Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc.
Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro?
Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Notes:
1.The pixel size of your clip cannot exceed 4000 x 4000 pixels.
2.If your imported clip appears distorted or stretched, its pixel aspect ratio may be set incorrectly.
Well Done. Enjoy Flip video editing in Adobe Premiere Pro with Flip to Adobe Premiere Converter.
Related: Flip camera review: The best flip camera after Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD.
on Aug 11, 2010 | Computers & Internet
Tip
Edit Flip Camera File with Premiere Pro
Premiere Converteris a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
Step 1: Load files
Notes:
on Aug 10, 2010 | Computers & Internet
My ADOBE Premiere Pro CS3 full version is loaded on my computer. I used it many times , but now when I tried to open it it just open and then closed
You have an illegal download. With the new Adobe Updater - it automatically checks for a valid key.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 13, 2010 | Adobe Premiere Pro CS3 Full Version for PC...
Capture HM-DH5U Video into CS4 Premiere Pro
Personaly I would use either windows movie maker, nero, or the applicatiom that came with the camera just to get it to the PC.
From there It would be easier to edit etc.
Aug 14, 2009 | JVC HM-DH5U 35-Hours Video Recorder
JVC GY-HD110U won't turn on with battery power only AC power.
There is an issue with the a small yellow part of the AC plug breaking off in the camera. The camera thinks it's still plugged in, so it won't run on the battery. If you can get a small tool to fit into the inlet you can break the piece up and pull the parts out. I haven't had any luck with it, but read others doing it.
Apr 24, 2009 | JVC GY-HD110U Camcorder
Adobe Premiere Pro Cs3 problem
the video format is not support this software . so you get the runtime error!
Apr 04, 2009 | Adobe Premiere Pro CS3 Full Version for PC...
JVC 580136 Camcorder Logo
340 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
