Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys WRT54gs I'am trying to connect to my Linksys WRT54gs router and make changes to security settings. The first page comes up but when I click on any thing else my browser says it cannot find the page. I can browes the internet just fine. PLEASE HELP
  • bjc1 May 22, 2008
    It is wired. Thanks for your responce but I was able to get with Linksys and found out that my antivirus and firewall was causing the problem.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    Is your computer wired or wirelessly associating with the router?
  • 611 Answers
Ya if firewall is there then remove it when you connected your net after then you give the friewall.
for the security settings you have to go for the router page and go there one option is there security enable go for it
Posted on Jun 13, 2008
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
I want to secure my connection
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Oct 13, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
Jul 21, 2010 | Zyxel P660HW-D1 Router
Setting up linksys wireless router security wep . Linksys WRT54gs V.5 router. I reset it back to factory defaults. Now I want to make it secure again.
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 07, 2010 | Linksys Wireless-G WRT54GS Router...
Need to find the security code for my wrt54gs
The security code is the encryption code that is configured in the wireless setup of the Linksys router.
To configure and secure your wireless router from unauthorized access, please click in this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Apr 01, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys router is connected to laptop but is not working as wireless
Your wireless on your router setup page is turn off. You have to log into your router and go to the wireless tab and enable the wireless, and I recomment to put a security settings of wpa or better.
Oct 22, 2009 | Linksys Wireless-G WRT54GS Router...
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
Secerity key
Just go to www.linksys.com/kb select the model no.of your router and you will get step by step help to setup your router. you can also call linksys tech. support and i am here to solve your problem.
if this is a new router then connect it to your system through ethernet cable and go to internet explorer and type 192.168.1.1 at the add. bar it will prompt for the password. leave the user blank and type admin in the password linksys setup page should open. now click on the WIRELESS TAB and on the basic wireless settings change the defale SSID NAME to your girlfriend's name and also click on reset security and click on save settings. reload the page and now go to wireless security tab and select WEP in the security tab. now type 10character password in the KEY 1 field directly and click on SAVE SETTINGS and that's it. Now when you connect to your network you will have to enter your 10 char password in your COMPUTER and it should work fine now. call tech support or go to the above link for further assistanceRICHARDM69
Dec 04, 2008 | Linksys Wireless-G WRT54GS Router...
My router is a wrt54gs wireless-g,but it is wired ether cable.
  1. Make sure that your game console is wi-fi/wireless ready.
  2. Check the wireless settings (SSID, Wireless Security) which are configured in your router. To do that you need to access your router's setup page.
  3. Launce IE from the computer connected to the router and type 192.168.1.1 which is the default IP address of Linksys routers. Then, it will open a window asking for a username and password. By default, there is no username. Type admin on the password field.
  4. Once you're in the router's user interface, click WIRELESS tab. Take note of the SSID or wireless network name.
  5. Then, click on a sub tab called Wireless Security. You will find there the type of security enabled in the router as well as the security key.
  6. These settings such as SSID and wireless security should be configured to your game console in order for it to connect to your wireless network through the Linksys router.
  7. Hope this helps!
Nov 16, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
