Question about Hansol Multitech 920p 19" CRT Monitor
19" hansol 920p monitor
Hi
i have recently moved house and had`nt used my pc for about 3 weeks. i set it up to day to find that the desktop does no longer cover all the screen. there is a 1 inch gap down the left and right sides of the monitor . the top and bottom of the desktop are ok. I.E the top is at the very top of the screen and the same for the bottom. its just down the sides. i have been into the menu settings on my monitor and tried to expand zoom but it is on max. i have also installed the driver disk that came with the monitor but still have the same problem. so basically i have something like a 17 inch screen on a 19 inch monitor. i have also tried adjusting the display settings but still have problems. can any one help me please as its driving me dappy. many thanks.
Colesy.
  • colesyboi May 21, 2008
    hi
    thank you both for getting back to me so quick. I think if it is something internal then i may aswell just buy a new monitor. been wanting a flat screen monitor for a while now. this monitor is about 5 years old so guess its done its job, its just annoying that the usual thing happens when you store something electrical; it packs up. once again thank you so much for your help.
    all the best,
    CoLeSy
    Scholar:
  • 143 Answers
Hi Colesy, it could be that your horizontal driver (IC CHIP) is going bad. There are two IC's that expand the picture on the screen. One for horizontal and one for vertical. When one of them starts to go bad, the screen starts to "squeeze" in on the top/bottom or sides. Eventually, there will just be a small line in the middle from top to bottom. You may need this IC replaced. I am not sure on the cost of repair should you have it done at a shop, but it could be prohibitive and you may just end up buying another CRT. Check around.
Posted on May 21, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
E screen of my monitor(computer) when i open a some game are shakin
DO U KNOW WHAT IS REGULATION?
AT FIRST KNOW WHAT IS REGULATION, THEN ASK Q.
Jul 01, 2010 | Hansol Multitech 920p 19" CRT Monitor
How to fix brightness on hansol 920p if it is already on max in manu? is there some button in case to do that?
There are ways to bring the brightness up in a CRT monitor. These should only be attempted by a servicing pro. There are extremely high voltages involved.
Mar 24, 2009 | Hansol 920 A 19 in.CRT Conventional...
H950
The backlight power supply in the H950 series suffers from a manufacturing defect. Hansol might replace the unit even if it's not covered by warranty anymore. Contact them.
Otherwise (and if you have electronics skills), replace the electrolytic caps in the monitor's power supply. Take proper high voltage precautions!
  • Disconnect mains
  • Wait at least one day for caps to discharge a bit
  • Remove monitor stand (four screws)
  • Put the monitor face-down on the table, plugs facing to you
  • Remove back cover (snap-in, difficult to open without minor damage) - be cautious: front buttons are connected using a rather short cable, do NOT try to remove front cover
  • Remove EMV casing screws (four screws) and ground wire
  • Disconnect CCFL tubes (four connectors), noting connector orientation
  • Disconnect front buttons pcb
  • Lift EMV casing side facing to you
  • Disconnect power supply board (left) from signal board
  • Unscrew/remove power supply board - caution: C12 is likely to store mains voltage even after days!
  • Replace caps (C34 and C66 are likely failure candidates for IPHS19-S rev1.2 boards; you might also replace C31, C32, and C35 while you are at it) - higher voltage and temperature rating are okay, capacity has to match
  • Assemble everything again
Nov 10, 2008 | Hansol H950 19" LCD Monitor
H950
  • Disconnect mains
Hansol H950
  • Disconnect mains
Jun 26, 2008 | Hansol H950 19" LCD Monitor
Some of those monitors have had a problem where the large HDMI cable attaches to the back of the monitor. Try inserting the HDMI cable then instead of tightening the screw supports power up the monitor and wiggle it slightly if the monitor works then the problem is in the connector and may need to be resolderd on the inside. have you tried using another HDMI cable to rule out that the cable itself isnt defective?
Apr 07, 2008 | Hansol H950 19" LCD Monitor
Hansol H950 19
Most likely the power supply, or the back-plane lamps, or the back-plane supply, or a defect on one of the processor boards is loading the supply too much, or any combinations of these are defective. You will have to have a source to try the boards to fix the monitor. I would suggest to find the authorized service rep for your monitor. They will have to service it for you. If the monitor is out of warranty, the fix will not be cheap!
Jerry G.
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Hansol Multitech 920p 19" CRT Monitor Logo
548 people viewed this question
Top Hansol Computers & Internet Experts
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Zakari Elothmani
Zakari Elothmani
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
