Question about Nikon N65 35mm SLR Camera
Picture won't take on auto
In auto mode, regardless of lens, the picture won't take; the lens zooms out and then back in, and the flask lights up, when I depress the sutter button, but the picture won't take.
Manual mode is fine. I know this is a simple adjustrment but don't know how to fix it
  • Anonymous Jun 26, 2008
    Same problem, even in good indoor lighting conditions, auto focus adjusts the lens but won't take the picture. Have camera for four years now. Problem just started
  • jmv23 Nov 29, 2008
    Same problem - autofocus has suddenly stopped working, after owning the camera for 7 years. Shutter does not depress in autofocus, but does in manual mode. Quantaray 28-90mmD lens.
    Novelist:
  • 121 Answers
Snoopytwo, jmv23 & guests,
Sounds like you have been taking photos in both auto & manual modes, make sure your f-stop is set at the range it needs to be to allow enough light for the camera to take the photo. Since the lens and the camera communicate, if the lens is closed down & not allowing enough light the camera will not take the photo - does that make sense - Look at the metering in auto mode and see what the camera says the conditions are for a specific lighting condition check to see if the lens has a aperture position for Auto, usually a dot on the lens ring to align with a setting in red or green (likely a F-22) depending on the make of lens, that has been moved to some place in the middle and not returned while trying other manual settings so the shutter won't release because the camera is told by the lens there is not enough light or slow enough shutter to take this picture.
randy320sgi
Posted on Jan 14, 2009
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My d80 wont take pictures in auto,P,S or A modes. Will click in M mode but no picture. What am I doing wrong? Treied to reset, but still does not work.
The camera will not take a picture in P, S, or A if the camera is in Auto Focus mode - and is unable to focus. Make sure that the Auto / Manual focus switch on the camera body AND the lens are BOTH in an Auto Focus mode. A tip off would be that you do not hear the lens focus motor running while trying to find focus.
If you do hear the focus motor, you may not have sufficient light on the subject for the camera to find a contrast "edge". In this case, the focus motor will hunt from where ever it is all the way in one direction, and then all the way in the other - trying to find focus. You'll need to provide more light or if you have the focus assist lamp (on the front of the camera) enabled - make sure your fingers are not blocking it while 1/2 pressing the shutter.
You can take pictures "all day long" in Manual Focus mode regardless of whether the subject is in focus or not. The lower left corner has a green circle or disc that indicates proper focus. Otherwise, a green triangle shape will be visible close by.
More info on Focus is available here. I hope this helps and good luck! Please rate my reply. Thanks.
Nov 07, 2011 | Nikon D80 Digital Camera with 18-135mm...
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
All of a sudden every picture I take with the 55-200 zoom lens is blurry and slightly out of focus. Pictures with the 18-55 lens are still sharp. I have been using that 55-200 lens for years for sports...
Simplest answer is that you may have accidentally flipped the focus switch (A/M) on the lens to M. This turns off autofocus for that lens (which you might need to do if autofocus just can't resolve the image). Try turning it back to A.
Another possibility is that you're using an autofocus target different from the one you're expecting. The problem would be apparent regardless of lens choice, by being in focus in a different part of the image. You can press the arrow keys (while holding shutter release down halfway) to change AF targets, or change a menu setting to simply choose the closest target.
The shooting modes have no effect on focusing ability.
The camera would likely detect other focus-related problems (like servo failure).
May 09, 2011 | Nikon D40x Digital Camera
I have a Nikon D70 (with a 18-55mm lens) and have always used it in Auto mode. It suddenly stopped working in auto mode...won't take the picture at all. Did I break the lens??? If I tip the camera back...
Hi tina549, do any of your other lens auto focus? If so then it may be this lens. If they do not then look on the right side of the lens mount (with camera facing you) there is the AF and M switch. Something to try is clean the electrical contacts on both the D70 and the lens. When I had a D70s the auto focus was giving me fits, worked sometimes then it did not so I traded it for the D80. The 18-55 lens is a nice lens however, it is not the most robust of lens.
Jun 11, 2010 | Nikon D80 Digital Camera with 18-135mm...
Lost all button functionality except power and shutter
There is a secondary battery I suppose for memory retension. It is housed where the other batteries and memory card are, the battery is a CR1220. I replaced that battery and things are working well again.
Jun 22, 2009 | Canon PowerShot A710 IS Digital Camera
Can't take pictures.
try zooming in on a object and see it it get clearer. the problem is your zoom lens motor is stuck or malfunctioning. This is a very common problem with digital cameras. sometimes you can take compressed air and blow around the lens and clear the blockage or lightly tap the camera lens down with it off to free up the focus gear. if it does now work it then needs tobe serviced or repaired. I had the same model last week for the same problem. That lens had tobe replaced. but try that first and see if it helps.
Apr 04, 2008 | Olympus FE-190 Digital Camera
Difference between the D-460 and the D-450 Zoom digital camera
The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Difference between the D-460 Zoom and the D-490 Zoom digital camera
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Nikon N65 35mm SLR Camera Logo
111 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
