Question about Samsung PCN5425R 54" Rear Projection Television
Convergence problems Hi my name is Brian i recently got a used 54" sumsung rear projection tv and there was a problem with it . I thought the problem was the convergence board so i ordered one off of the internet. i installed the board and turned it on and got a picture but then it shut off and it wont turn back on. Any suggestions would be great.....
  • Samsung Master
  • 8,617 Answers
Did you buy the board new or used? It could also be your convergence Ics and not the convergence that is causing the shutdown . The convergence ICs are not located on the convergence Board.
Posted on May 22, 2008
We have 52 inche akai and it shows double inmage
This problems is known as a convergnce problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergnce board,must be replaced to solved the tv covergence board.To solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole rebuild convergence board to replaced.The Akai/Samsung tv used the same convergence board.
Sep 15, 2010 | Akai PT5492S 54" Rear Projection...
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
Cannot manually Converge Samsung PCL545R 54 in. Rear Projection Television. Perfect focus doesn't work either.
Try website like Tv repair World.com to buy a whole convergence board to replaced.Samsung/Akai use the same convergence board.
Apr 26, 2010 | Samsung PCL545R 54" Rear Projection...
Convergence board is bad
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
Akai PT5492S 54" Rear Projection TV
Your set needs to have both Convergence ICs replaced they are Both STK392-010 you can get new ICs at the following link and they provide free step by step instructions with pics so you can do the job yourself which takes about 45 minutes. Heres the link.
http://servicemanuals.vstore.ca/
May 10, 2008 | Akai PT5492S 54" Rear Projection...
Not having much luck with this convergence
MrPeab,
Is it possible you missed one of the wire connections on the convergence module? My other thought is, are you attempting this setup with the factory original remote or a universal?
Bill
Mar 14, 2008 | Samsung PCN5425R 54" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
Jan 20, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue horizontal bows/lines
Replace convergence IC's,then check alignment.
Use OEM quality ==I use Panasonic IC's with no call-backs.
T.
Oct 13, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung 54" Projection TV (PCN5425R)
sears does inhome service, if you do try to fix it, there is usually a board mounted to the back of the tubes (above the others), if it has this convergence board, try unplugging the red connector with the blue wire and turning set back on, if it powers with a 3d looking picture, you have a bad convergence module. Other than that you may want to call a repairman.
Jul 08, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
