Question about GE Microwave Ovens
Model jvm1631wjol code f-3 comes on and just beeps.
  • GE Master
  • 8,865 Answers
On a GE, F3 usually means a shorted keypad. We replace these for customers nationwide for $39.95 plus parts.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on May 22, 2008
Neff - reduce the beeps
I notice you did not list the make and model, but in general they beep 3 to 4 times or more, it is not uncommon for some to give more. If you have your owners manual there might be a option offered, or contact the manufacture and talk to customer support and the technical department for a possible solution.
Apr 03, 2012 | Microwave Ovens
Getting error code F-3, microwave beeps with this code, entering Clock, then the time clears the code, then can use microwave, but after sitting code comes back on. Have tried unplugging oven for several...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad. It can be intermittent.
On some models, the keypad can be replaced as a separate part.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
But on some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
In order to solve the problem this is what I did (with a help of Mr. Hilik
@ www.microgal.co.il)
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Jan 30, 2010 | Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Ge microwave spacemaker xl1800
F-3 means shorted touch panel pad. In order to attempt clearing the code yourself, please follow the steps below:
  1. Press CLEAR/OFF or CANCEL.
  2. Program control again.
  3. If the fault code appears again, disconnect power to the microwave for 30 seconds.
  4. Program the cooking function again.
  5. IF it comes back up you should change out the panel hope that helps, good luck
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
