Question about Onkyo TX-SR605 Receiver
Volume on my Onkyo Receiver
I have an Onkyo 605 receiver with the Bose Acoustimas 10 speaker set up. I just set it up last night and have noticed that the volume on the receiver has to be at 55 for normal TV listening. Is this normal?
  • 1 more comment
  • jcrows Dec 28, 2008
    I was wondering the same thing because I have the same setup as the thread poster. Does your Bose system seem to begin distorting around a volume of 75 or so?
  • devon_wendel
    devon_wendel Oct 07, 2012
    need morfe info on how you are set up to ansewer this.. it could be as simple as a dual volume level (not fixed out) volume level.. It could be cause you should have a baught a better cheaper more effcient speaker system like JBL:))
  • devon_wendel
    ohh duhh.. are u guys using the cheap speaker wire I assume Bose still provides.. Get @ least a good 14-12gauge and his should solve ur problem! Bingo!
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
Posted on May 21, 2008
Bose Cinemateonnect
Hi lechap,
With the indulgence of IB4G2008 as per his last post Feb 13.....
If I figure your concerns right, they are:
1. You have an iPod on an Onkyo IPod dock that you want to connect to an Onkyo receiver TX-302;
2. You have an Onkyo receiver TX-302 that you want to power a set of Bose Cinemate speakers;
3. the connectors on some do not fit or are not the same;
4. you want to know what goes to where.
If I may suggest:
a. connect the L/R Audio Out of the Onkyo IPod dock to the L/R Audio IN of VIDEO 1 using a pair of RCA to RCA cable. Connect the S Video Out of the Onkyo IPod dock to the Video IN of VIDEO 1 using an S Video to RCA Video cable. Thereafter if you want to watch a movie or play music from your iPod, you need to choose Video 1 in the Onkyo receiver TX-302. You can of course choose any other VIDEO 1~3;572fcdc.jpg34ab5d3.jpg
b. all other source/devices may be connected similarly using the same scheme on any of the free VIDEO / AUDIO inputs
c. of course the MONITOR OUT goes to your TV or projector.
With respect to the Bose Cinemate, it would not be technically correct to connect the Bose Cinemate speakers straight to the speaker out of the Onkyo receiver TX-302. You need to install another set of speakers to the speaker outs of the Onkyo receiver. The Bose Cinamate system's TV AUDIO could be connected to the TAPE OUT (or the AUDIO L/R OUT of VIDEO 1)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 13, 2008 | Onkyo TX-SR302 Receiver
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Audio problem - Bose Acoustimas
Go into the parameters setting for your receiver and make sure that your levels are at least matching all outputs. If this is not the case, suspect wiring or a problem with the amplifier. Oh, and last but not least, make sure that the receiver has at least the "speaker A" option switched on...accordianman
Jan 27, 2008 | Bose Cinemate Digital Home Theater System...
Speaker volume settings
I figured out the problem.  After you set the individual channel volume for each speaker you need to push the test button on the remote and this will lock in the settings.  Thanks.
Oct 24, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-SR605 Receiver Logo
733 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
