Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Get no connection useing 6100 modem connected to wireless B router
My friends computer is running XP and is connected to the 6100 modem through the usb output. I connected my Linksys wireless-B router to the modem useing the ethernet output. My laptop finds and connects to the wireless router, but will not connect through the modem to find the internet. I am just learning about networking so please take it easy on me with the answer. Thanks in advance. KP
    Scholar:
  • 68 Answers
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
Posted on Jun 11, 2008
I have another computer i want to install in the up stairs.do i need another dsl router to connect to it????.
If you have a Westell 6100, it's just a modem meant to connect a single computer to the Internet. It has the jack where you plug in the cord to your DSL phone line, and an Ethernet jack so you can plug in your computer. You can't have more than one of these connected to the phone line because of address conflicts that would result.
What you need is a wireless router so your Internet connection can be shared by several computers. Most service providers are installing Westell models that combine the modem and a 4-port wired/wireless router for new customers now. Since you have the modem only, you'll need to supply the router. The wireless function lets you use the upstairs computer without having to run a network cable to connect it. That's much cleaner and simpler. There will be four connectors on the back of the router for wired computers or other things (such as a network printer) you might want to connect. You still have only one connection to your DSL line, but now you can hook up several computers at once.
There are several companies making wireless routers and they all do pretty much the same thing. Netgear, Linksys and D-Link are the most common, and you can buy a wireless router at almost any retailer that sells computers. You can also find them online from companies like TigerDirect or Newegg. Other than staying with one of the major brands (it's easier to find support for those if you need it), there's not much to recommend one kind over another.
It's pretty easy to install a wireless router and set up your wireless network. They all come with a CD containing setup software that will guide you through the process. You'll have that upstairs machine on line in no time.
Dec 05, 2010 | Westell Wirespeed LiteLine 6100...
ZyXEL P-330W wireless router
No it will not work you cannot connect a router to another router wirelessly and it will most likely not be detecting each other, routers are built to transmit internet signals from modems if you have a router and a computer but you do not have your own internet connection that will not work conencting to another router you will need USB Wifi Card transmitter/reciever to be able to connect to your friends wireless internet.
but if your friend only has a modem you can lend him your router and get a USB wifi transmitter/reciever to be able to connect to your router that is conencted to your friends modem this will work but will not work if you and you friend will both have a router creating a network.
Jun 20, 2010 | Zyxel Prestige P-330W Wireless Router...
Unblocking
That Westell is not wireless so the short answer is no.
However you can buy a used wireless cheap on www.craiglist.org for not too much. Wire the wire that is going into your pc into the NEW WIRELESS MODEM you get and then set that to run the first one to your PC and then you will have wireless as long as the modem you put into the mix is wireless.
XP - Vista and especially Windows 7 makes wireless a breeze.
One last note - Some internet providers do not like you to set up home wireless systems - and they sell wireless units - or 'rent' them for extra money. So -you might check with them. There is no law against setting you your own network but the ISP or what is called your provider will know and some don't like it - so if you loose connection after setting up your network - check FIRST with your ISP -- to see if they are messing with it - [ not saying they are - just saying]
Best of it
Mar 27, 2010 | Westell Wirespeed LiteLine 6100...
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
USB Connection
Hi floinmist .
Westell 6100 modem by default can only be used for 1 PC . It cannot orit is not enabled to use for 2or morer computers as it creates a conflict within. Ethernet connection is the BEST connection for you to use.> your USB is sent to you by you provider { ISP} or by westell packages. Its is only a spare cable just in case your PC doesnt support ethernet connection ,  nothing else.
To resolve this issue you might want to upgrade your modem to a router w/c is westell versalink . You can connect 2 or more computers  { wired or wireless connection } and is more stable compared to your westell 6100.
Connecting 2 computers could cause slow, intermittent and NO connections at all problems.
IF you have other questions pls feel free to ask and let me know if theres anything ii can assist you with .
Best wishes.
Prince
May 02, 2008 | Westell Wirespeed LiteLine 6100...
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
371 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
