FixYa.com
Tags:
Receivers
Generic problem for all Denon Receivers
My denon avr-a10se stop working.
posted by eharoush on May 20, 2008
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 21, 2008
Not Rated (0)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 596 votes
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
Dan
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Denon AVR-1601 5.1 Channels Receiver Denon AVR-1803 6.1 Channels Receiver Denon DRA-365R Receiver Denon AVR-3600 Denon AVR-600 Receiver Denon DRA-565RD Denon AVR-2600
Can you Help with these Receivers problems?
Receivers
cannot enable wireless adaptor...
cannot enable wireless adaptor... Answer This...
Receivers
I have a pair of
I have a pair of jbl L110... Answer This...
Receivers
1996 Ford Falcon radio code
1996 Ford Falcon radio code Answer This...
Receivers
sub woofer hum sub333
sub woofer hum sub333 Answer This...
Receivers
need user...
need user... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
