Question about Canon CLC 1120 Color Copier
CLC 1120 code e071, sub code 001
This 1120 has 40,000 copies and is powered by a firey model V55 colorpass. When sending a file, the machine shuts down at the end of warmup. When the problem first started, the file would go to the CLC, print 2 or 3 copies, then post the code. Then it started posting the code when the program loaded but prior to printing. Now it will not even allow the file to load to the CLC. We have checked and cleaned all contacts, drum, paper path etc, but don't know where to go from here. HELP!
The Brake Man, Inc
  • brakeman May 28, 2008
    The paper was the problem for the above problem but when we turned the machine off then back on, we now have a new error code 020 sub code 0181. The machine instructs us to turn it off then back on, but nothing changes. HELP!
Nothing But the problem is in Magenta Developer unit. The toner dencity is +/- 5 higher or lower than 0.
If problem persists change the magenta developer.
S.N. Kampa
Posted on Sep 25, 2008
    Problem Solver:
  • 6 Answers
There maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
Posted on May 27, 2008
Canon CLC 1120 shuts off immediately. On/off flips to OFF
you had resets the power regultor of the machine press the same button then turn ON the machine when the machine came on relese your hand from the button
Jan 15, 2015 | Canon CLC 1120 Color Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
E020 sub-error 0273
go into service mode function or adjust and put in all the door spects take machine off then on do a graduation adjust
Sep 05, 2008 | Canon CLC 1180 Copier
Not printing correctly from computers
try makling a copy from the glass if that is good then your problem lies with your net work try reboothing the colorpass, also have someone else print if you still have blank prints your color pass hard drive needs to be detach blow out then reattach
Jul 10, 2008 | Canon CLC 1140 Copier
Victor enriquez
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors there may be toner or paper dust
May 15, 2008 | Canon CLC 1120 Color Copier
E071 0003
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Apr 15, 2008 | Canon CLC 1120 Color Copier
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Canon
This has to do with Potential Control - without a sub code I can't direct to a more specific direction. How many copies are on the drum?
Nov 07, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
245 people viewed this question
old marine
old marine
