Question about iLO 2600 Television
None of the keys working ilo hd26
I have ilo 26hd Only power key is working, volume, channel, and all other key is not working channel stuck on 3 please advise
thanks
  • macsdaddy May 29, 2008
    I have the same problem. The model number of my TV is iLO26HD. None of the local repair shops aren't able to help.
    Problem Solver:
  • 5 Answers
The stuck remote happened to me. I had accidentally pressed the favorite button instead of flashback button. after pressing favorite again, remote worked again. This happened a second time--same fix.
Posted on Aug 22, 2010
Main board must be replaced
Posted on Jun 13, 2008
4 Suggested Answers
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
Coldcut
  • 1554 Answers
SOURCE: 26 ilo tv comes on but stuck in composite no functions on side works except for power switch
I would contact them on this
http://www.funai-corp.com/support/contact.aspx
in the manual see page 34 for testing the remote
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Posted on Jan 31, 2008
  • 5 Answers
SOURCE: my tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Need the tv code for an insignia tv
The most popular code is 10171
if this doesn't work, you can try 10463 or 10842.
a possible alternate code is 10178.
If none of these work then try the following:-
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this. StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    • 1 for Televisions
    • 2 for "AUX 1" devices - VCRs or DVDs
    • 3 for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
source directtv.com
DIRECTV Remote Control Code Lookup
Mar 17, 2015 | Insignia Televison & Video
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
My JVC kd-r310 powers on, plays the cd, but none of the controls work. it's stuck at one volume, playing all the way through. literally NONE of the buttons work. The first time it happened it was easily...
My guess is one key is stuck inside. Try press and release all keys one by one and check if any feels different. If that does not work, you can try take the radio out, make sure you have your radio code, and unplug all cables, then press power for 3 seconds (yes press the power button with everything disconnected), plug in cables again power radio On. If the issue persists you will have to go and see a technician.
Aug 30, 2013 | Car Audio & Video
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Ilo tv is stuck on one (1) channel
call 909-974-2859, they have the parts and tech support for this TV.
Sep 16, 2008 | iLO 3200 32 in. LCD Television
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
May 01, 2008 | iLO 3200 32 in. LCD Television
Jan 26, 2008 | iLO 2600 Television
Volume/ channel/ remote not working
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
323 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
