Question about Garmin StreetPilot C320 (010-00401-00) GPS Receiver
Problem using my C320Garmin when plugged in
Hello, my problem is this - when I plug the unit into the cigarette lighter in my car and use the unit, the battery eventually dies, so I don't think it's charging when it's on. If I plug it in when it's off, it says it's charging, and I believe it does charge, but I have to leave it off. That kinda defeats the purpose, if it's plugged in shouldn't it work?
  • 640 Answers
You are correct,however do you have an upgraded audio system (amps,subs ect?).If so your altenator may not be able to keep up.Also look into the system settings on your garmin and make sure the power settings are right.Let me know
Posted on May 21, 2008
    President:
  • 2,712 Answers
I had the same problem. Solved the problem by replacing the cable..
Only other solution is charge it via the USB port of the computer or an external wall charger.
    Genius:
  • 1,665 Answers
Check the plug in to be well fitted. perhaps looses connection.
Cigarette lighter keeps blowing fuse
when the lighter is not pushed in does the fuse still blow? If not get a new plug in bit. Try some other plug in unit (GPS--dash cam--tyre compressor) or anything that uses a plug for the cigarette lighter and see it the fuse still blows.
Dec 07, 2013 | 2007 Kia Optima
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Cigarette lighter does not work
first check the fuse, next, get a light tester and see if you getting power to the lighter unit. two wires to your cigarette lighter one black for - and red for +, if you getting power, your line is good that mean your cigarette lighter unit does does not have a good contact to what ever is plugging in. replace the unit; if no power to the unit, test the cigarette fuse and see if the wire is hot. if not you have a short to the fuse. hope that help some..good luck
Jul 07, 2009 | 2000 Ford Taurus
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Can not figure out how to charge the Vector start it pro
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
Feb 21, 2009 | JUMP START SYSTEM
NO OUTLET TO PLUG INTO CAR
Most GPS would have a cigarette lighter adapter to charge the unit while in the car. If you vehicle has onle 1, then it would be needed to pullout the cigarette lighter and use that for the charger. If your unit does not have a cigarette lighter adapter/charger, then pls post back the brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Garmin GPS
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Garmin StreetPilot C320 (010-00401-00) GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
