Question about PfaFF Hobby 4260
Pfaff sewing machine 463
The thread continously gets caught in the bobbin area and the machine will not sew.
  • fypeyre Dec 02, 2008
    I am looking for the instruction book. Do you get it?
  • Anonymous Mar 28, 2014
    thread is caught in the bobbin well
How do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
  • Ola Kinberg Dec 02, 2013
    Pfaff 463 is thread starting from the top of that pin on top of the machine. Thread comes out on the side so let it pass through the other hole in that pin. Then go thru the flat thing with several holes. Go through it two or three times. Then just like most other sewing machine. With one exeption: i reckon its better to let the thread run outside that bar that intentionally according to the manual is supposed to keep it close to the needle. Onemore thing: thread is going into the needle frome the left and the flat surface on the needle is suppose to be to the left.
Thread shred. Pfaff 463. Using 120/19 new needle. And Sunguard Anti-wick UVR bonded polyester thread for marine canvas. Why is my thread shredding?
From my past sewing experience (not an industrial machine), the thread will shred if the needle/thread/fabric are incompatible. Could be the canvas is too coarse and is wearing on the thread like sandpaper. Remember, the thread/needle will penetrate over 10 times before that section of thread actually forms a stitch, so that's a lot of friction going on. In regular sewing, a top-stitch needle has a larger scarf which acts to protect the thread, however, not sure that is a choice for your machine.
http://www.upholster.com/upholstery-forum/index.php?topic=11340.0;wap2
Is Pfaff 463 Suitable For Upholstery
Pfaff 463 Instruction Book
May 19, 2017 | PfaFF Sewing Machines
The needle on my Pfaff 2044 won't move and the wheel won't turn. What do I do?
There may be thread caught in the bobbin area which is not allowing the hand wheel to turn. Remove the bobbin case and check the hook for threads wrapped around the spindle and/or caught in the hook mechanism. A little clear sewing machine oil in a pipe cleaner is sometimes helpful in freeing threads in this area.
Feb 15, 2015 | PfaFF Sewing Machines
My creative 1473 pfaff will only ball up the thread on the back of the fabric. I have triple checked the threading and am sure the bobbin went in correctly.
I would. rethread the machine. Make sure the bobbin is inserted correctly but clean the bobbin area and look closely for any threads in the bobbin are before you insert it. Make sure the tension is set correctly and there are not stray threads caught in the tension anywhere along the way.
Jun 30, 2014 | PfaFF Sewing Machines
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
I have acquired a pfaff 463-34/01 machine and require needles bobbins bobbine holder/s and a handbook Can you help? Regards peterjjohn@tiscali.co.uk Tel 01829 270931
i have bought a pfaff 463 machine and when i sew the thread going through the needle keeps on shreading..... any suggestions
Feb 08, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
612 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
