Question about HP DeskJet 5550 InkJet Printer
Some print lines fade out making a poor copy
I'm using a new recycled cartriges of ink and my print quality isn't good. I cleaned the cartrides but its still happening. Can you help?
  • cosman May 11, 2010
    did you refill your self or not?
  • HP Master
  • 2,794 Answers
If you are seeing lines it is the cartridge and it's bad.
Refilled cartridges usually only work about one time and then the cartridges run into problems. They either leak or the cause lines in the copies.
If you can return and get a non refilled one, that should work.
Posted on Jun 21, 2008
My workforce 520 printer renders illegible document printing and copying. my alignment page is not sharp either. should i trash it or can it be rehabilitated?
Factory reset, and then clean your printhead with the built in cleaning protocol. Make sure that the print quality on your computer is set to the highest resolution (best DPI) and best quality setting (usually image) that will fix the problem but also significantly increase the ink usage.
Note: using non-standard ink (ie Cartridge World ink or recycled ink cartridges, or refilled cartridges) can lead to poor print quality.
Jun 07, 2015 | Epson Office Equipment & Supplies
Hi. I have replaced my ink cartidge twice but the print quality remains faded with some white lines through the text. Does this sound like more than just a poor quality ink cartridge problem?
Print heads bad or dirty, as well the cleaning sponge is no doubt in need of attention. They can be replaced but the economics are spendy. Good Luck
Dec 09, 2010 | Brother MFC-5440CN All-In-One InkJet...
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Computer says no ink in color cartriges,but there is ink in them
Probably just a miscalculation and/or an incredible use of the ink during cleaning. Either way you will need ink. Do not take these estimates literally as they are only estimates. You could try setting your default print quality lower to 'draft' and override for printing photos to save ink.
Dec 13, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Cleaning the Xerox Workcentre Pro 575
More than likely, you have a bad toner cartridge.
Nov 12, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Poor colour quality
usaully the problem is when using refill ink. It damages the ink cartrige
Mar 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
My printed and copied pictures have horozontal lines
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
Mar 14, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
83 people viewed this question
Ben Johnson
