Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Lamp conection I just got the lamp and i dont know how to conect to the tv, it look like it was glued together.
YOU PROBABLY BOUGHT THE LAMP ALONE, AND NOT THE CHASIS. THAT IS FINE, NOT TO WORRY. THE LAMP IS PLUG TO THE CHASIS WHICH OPENS BY UNSCREW COUPLE OF SCREWS THROUGH A HOLE ACROSS. YOU HAVE TO GET A VERY LONG SCREW DRIVER THAT REACHES THAT FAR BELOW, ONCE YOU DONE THIS, THE BLACK PLASTIC CHASIS SLIDES OVER FROM THE ALUMINUM BASE, AND VOALA, YO CAN REACH THE LIGHT BULB. NOW, THERE IS ANOTHER LITTLE PROBLEM. THE ORIGINAL BULB MIGHT BE WELDED TO TH TERMINAL, AND YOUR BULB HAS EITHER A HOOK "t" OR "NOTCH", OR SIMPLY A TERMINAL WHERE YOU CAN JUST PLACE A NUT TO TIGHT UP THE POWER LINE. AND THAT IS ALL
Posted on Jul 30, 2008
I installed new lamp comes on then goes off and I hear a buzzing sound. Could it be that it's not installed properly for get light to come on. I had to use different screws because the new lamp didn't
How do you know the solution is "simple"? No always is simple. Bussing is high voltage missing. Like is bad conection to the lamp. Check conections of it.There is some bad about the conections of lamp. I guess.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
Support thomson roc 4239
new remote control for sensia pure radio has new barreries in it can you tell me whyit does not work
Sep 29, 2013 | Televison & Video
I would like to conect my laptop to my LCD TV,I did it before but now I can not do it,I have 14 pins VGA cable conected direct to the TV -PC outlet. TV is seted on PC input. Please help me.
Press FN button together with the function button on your keyboard that has the image of 2 monitors. try pressing these button together and see if you can come up with a selection on your screen. There are 3 options under this function. It will be the main monitor option, Extending monitor 1 to monitor 2 option and lastly disabling monitor 1 while using monitor 2 option.
Should you have any other questions just please leave a message.
Cheers~
Musicaddict
Sep 11, 2010 | Computers & Internet
Why wont it conect to internet i dont know
Make sure that the computer supports WIFI.
and also if you using a laptop, then you should change the settings in the laptop...
Jul 10, 2010 | Nintendo DSi White Console
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
How do you conect your sound rocker to your tv
if you have a game system that you try to use the sound rocker for sound you either have to by a cord connector or if you have the Xbox360 with the hdtv cord you can connect the cords to the sound rocker and the tv
Apr 12, 2009 | Pyramat Sound Rocker Gaming Chair
Problem with my cdr4170
can i connect cdr 4170 to my tv screen?
Dec 26, 2008 | Clover Corporation CDR-4070 Video Recorder
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Conection inalambric
The XBOX 360 can only be connected via an RJ-45 ethernet wire to the router unless you purchase the wireless adapter. The adapter can be bought at any accessory store such as walmart, Target, Gamestop, etc.
Jul 27, 2008 | Microsoft Xbox 360 Console
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
