Question about Nintendo DS Lite Console
Charging my ds lite
When try to charge my ds light the orange light only blinks for .5 second. ive tried different outlets already, and wiggling. hell i even tried praying. but nothing works. can i fix this without returning it?
  • 3,037 Answers
You shouldn't try to fix it if it still is under warranty. Return it right away for a new one. If it's not under warranty, let me know and I will give you some options to try to get it working. Please let me know your situation with the warranty and I would be happy to help.
Posted on May 21, 2008
Why does light go on then immediately off again and my Nintendo D S won't charge Why does the light go on then straight off again and my Nintendo lite wont Charge
Is the light blinking while you wiggle the plug? If so there are one of two problems one is that your cord is broke. Or two the jack on your DS is broken. Try replacing the cord first as it is cheaper.
Feb 16, 2015 | Nintendo DS Lite
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
Jul 06, 2013 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
Ds not charging
the mainboard has 2 fuses nown as f1 &f2 it could be they have blown you can get them on ebay
Jul 26, 2009 | Nintendo DS Lite Console
Nintendo DS lite won't charge
the fuse docent work anymore, its burn out. You can brige it with soder.
Jun 04, 2009 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Charging.
the ds lite sounds as if it,s damaged.
the problem with using adapters from other consoles, is that if the output voltage is higher, or the polsrity is different. the ds will be damaged. if you look at the back or underside of the ds. it should say for example. DC 9v. if you have used a 10-12 Volt charger, this has damaged the consoles mainboard fuses.
the other thing is the polsrity. whether the inner or outer section of the connecting plug is positive/inner and negative outer.
this can be viewed with a round symbol. with a plus in the centre or outer edge of the connector.
the only way, to get it working properly, if it isn,t already damaged is to get a charger of identical voltage and pin/polsrity.
Mike @ Compurepair.
May 20, 2008 | Nintendo DS Console
Not charging
Quite honestly...
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT=
Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
Regards,
Cyryl
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
