Question about Linksys WMP300N Pre-802.11n Wireless Adapter
LOW SIGNAL I need help on how to get better signal on the linksys wmp300n pci networkcard adapter I have windows vista home premium. Is there anything I can do buil an antena or how to make the wire bigger. Please help!!!!!!!!!!!!!
  • 4 Answers
Usually our CPU is on the floor or under the table, the common problem is signal, try to put your CPU on the table to roam a wider range. if still not much signal, just change your antenna with a better one.
Posted on May 23, 2008
I have wmp300-n card. I install card (software & drivers). The wireless works fine for about 20 minutes then pc freezes up. I have tried to uninstall software that came with it and let windows run it,...
i had that problem with another adapter, then i figured out that i was having problems with another pci adapter. so if you have another pci at the same time, try unplugging it and left the wmp300n alone, it worked for me
Apr 25, 2010 | Linksys WMP300N Pre-802.11n Wireless...
Media center won't connect to analog TV signal
If my memory serves me correctly, you need vista pro. home just isn't powerful enough and not made for it.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
Wireless Network Disconnecting
u have to reset your wifi router.
reset switch is in back of router and configure asgain.if u not need static ip then comfigure as dhcp
Jan 06, 2009 | Linksys WRT160N Wireless Router
Windows Vista Home premium problems
hi sir.
i think windows vista makes the system slow.. due it uses more RAM CAPACITY. so, try it in a windows xp. it work's properly.. thank's sir..
Sep 03, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Nothing detected on PCI slots
it seems your pci slots are dead plz try with other pci card if it is detect then ok otherwise you ask for replacement
Apr 28, 2008 | Computers & Internet
Vista compatability
y dont you try the other way round you become the host and update the setup to compatible with vista drivers then try and use the things!!!see if it works for you otherwise i will try and suggest another solution
Jan 31, 2008 | MSI : MP54G Wiress 802.11g Mini PCI Card...
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Wireless signal degredation
Disable and renable wireless card, even try unistalling the wireless card and reinstall it. update driver for wireless card. then if those fail, put pc next to router if signal still bad then card needs replaced. If your ISP didnt have you power off the router for 30 sec then do so.
Nov 18, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Linksys WMP300N Pre-802.11n Wireless Adapter Logo
154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
