Question about Haier HDN455 Dehumidifier
THE DEHUMIDIFIER JUST QUIT WORKING AND IS COMPLETELY DEAD AND IT WILL NOT MAKE A SOUND
THE UNIT JUST STOPPED WORKING AND WILL NOT MAKE A SOUND
The dehumidifier just quit woking. But light comes on, saying tank is full.
Posted on Nov 11, 2011
It will not turn on. Is there a reset button? It worked fine for over 5 years, then it just quit.
Hi, Sounds like the circuit board...they often will just do that...IF you can get one it will be half the cost of a new unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Maytag M7DH65B2A Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Not collecting water,
IF THE COMPRESSOR QUITS IT WILL NOT PRODUCE MOISTURE COULD BE LOW ON GAS,BAD HUMIDISTAT,DIRTY CONDENSOR CAUSING UNIT TO OVERHEAT SHOULD SEEK TECHNICIAN
Jul 20, 2009 | LG DH30 GoldStar Dehumidifier
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
Will not turn on
Boys and girls, I hate to tell you this -- but those units are DEAD. I had the same problems as being discussed here (not turning on, electronic chirp, bucket full signals), but with one other important feature -- the unit became so hot that I couldn't touch the top. At first it sounded and smelled like the fan was jammed, and later it sounded like the compressor wasn't working.
Anyway, after two weeks of dealing with LG (1-800-243-0000, and be prepared to call back several times as they have a phone problem), they have finally decided to refund me the money on my unit. Give them a call and speak to them. Also, as my unit was intermittently working, I would recommend that you unplug your malfunctioning unit if you are having these problems. A dead dehumidifier is one thing, a house fire is quite another thing.
Aug 24, 2008 | LG LHD45EL Dehumidifier
Dehumidifier stopped working,then started up,but making strange buzzing sound and does not collect any water
Try cleaning the coil and filter. They may have collected alot of dust and this could have caused the issue. If it is still doing it after you clean it the issue may be thecompressor. If the compressor is bad it may be cheaper to pick up a new unit. I recommend picking up one that has an energy star rating. They are usually made of higher quality materials and will save you some money on your electric bills. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 23, 2008 | LG LD65EL Dehumidifier
Check Zener Diode ZD2 on the board to see if it's shorted.
If it's shorted replace it.
May 20, 2008 | Haier HDN455 Dehumidifier
Will not run after a few seconds
sounds like a main pc board and or capacitor problem
Sep 17, 2007 | Kenmore 54351 Dehumidifier
1 yr old and Stopped working
the beep sound means that there are ac voltage in the unit but you gona need a tech there is no removal parts in that board and sound as a bad ic is there..good luck
Aug 05, 2006 | Kenmore 54701 Dehumidifier
Haier HDN455 Dehumidifier Logo
172 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
