Question about Microwave Ovens
Russell hobbs microwave turntable wont turn
We plugged it out for a week while on hols and when we plugged it back in the turntable wont turn, It still heats products but not sure if its safe to continue this either when the table is not turning. Everything else is working on it time,options ect..
  • PamelaNsrq Jan 16, 2009
    our turntable won't turn at all. It rotates by hand quietly and smoothly....but will not turn when microwave is on... how much is a motor for a frigidaire series PLMV169DC and how can you tell?
  • GA Dawgs Jan 31, 2009
    The turntable quit working on my frigidaire microwave (PLMV169DCD). When turning it, it sounds just like the one shown on youtube. Suggestions? Thanks
  • Microwave Ovens Master
  • 9,086 Answers
Is there an option via the Help or Custom Help to turn the turntable off and off?
This feature is common in over the range models.
Otherwise, it may be a bad motor.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
Please write back with your model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
    Problem Solver:
  • 11 Answers
Well I have the opposite problem. Turntable works but doesn't heat.
Posted on Apr 07, 2009
Russell hobbs hob sjs21
Usually you have to remove the jacket from the microwave to reach the release mechanism.
Nov 03, 2017 | Russell Hobbs Microwave Ovens
Have lost instructions for russell hobbs oven/microwave model no RHM20105-H serial no 0133100063
I think this the manual your looking for. That 5 is the model appears to be a S instead. Roll your mouse over the large black rectangle for pop-up download menu.
Russell Hobbs Microwave Oven User Manual ManualsOnline com
Dec 24, 2014 | Russell Hobbs Microwave Ovens
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Russell hobbs support
Clean the orifices on the bottom of the plate with something small enough like a toothpick to clear out the holes on the sole plate.
Mar 17, 2014 | Microwave Ovens
Microwave turntable not turning
Possible that the belt has failed, possible that the motor has failed or there is no power to the motor from the panel board.
You need to remove the bottom plate to check the belt , drive and the motor, check the voltage to the motor to confirm
Jan 31, 2013 | Russell Hobbs Microwave Ovens
Russell Hobbs Microwave ,it heats the food but it does not turn round.
If the oven is STILL heating, but the carousel isn't turning, the symptoms you describe are commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is usually about $25 to $45 (U.S. Dollars). If your model number is not listed at all the sites, you may also try these sites that carry the Russell Hobbs brand parts:
http://www.russell-hobbs.com/parts.shtml http://www.directpartsandproducts.com/index.php NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
Feb 02, 2010 | Microwave Ovens
How do i set the clock on my russell hobbs microwave?
wait till 1:01am and then plug in the machine, that seems to be where the clock always starts from. That how i do it lol = )
Jan 02, 2010 | Microwave Ovens
Russell hobbs cjs28 microwave oven user manual
sir i have a need of owners manual of russel hobbs cjs28 if u have it then plz... send me immediately on this address rehmanmunawar@yahoo.com
Sep 17, 2009 | Microwave Ovens
Microwave Ovens Logo
826 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
