Haier HDN455 Dehumidifier
Problem for Haier HDN455 Dehumidifier
THE DEHUMIDIFIER JUST QUIT WORKING AND IS COMPLETELY DEAD AND IT WILL NOT MAKE A SOUND
By HAPPY39 on May 20, 2008
THE UNIT JUST STOPPED WORKING AN IS COMPLETELY DEAD.
Same Problem
May 02, 2009
-   what is the specs on zd2
-   Guest
Best Solution
posted on May 20, 2008
Very Helpful)
Basti
Rank: Wiz
Rating: 85%, 803 votes
did you check the fuse? when you said dead do you mean not powering on? whats the exact model? thanks!
Was this helpful?
Yes
No
Solution #2
posted on Oct 12, 2008
Very Helpful)
abc5
Rank: Apprentice
Rating: 100%, 7 votes
Check Zener Diode ZD2 on the board to see if it's shorted.
If it's shorted replace it.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
Somewhat Helpful)
coolguy008
Rank: Wiz
Rating: 83%, 589 votes
The only solution to fix this is to get it repaired.
the only thing you can check is that the bucket switch is not hung up, or in fact a wire has not come off it. If you have power going to it, the next step would to be is to see if the on/off switch is working.
Goodluck..
Was this helpful?
Yes
No
Popular Solutions for Haier HDN455 Dehumidifier
Questions and Unsolved Problems for Haier HDN455 Dehumidifier
Do you recommend Haier HDN455 Dehumidifier?
Answer
Answer
Unit runs but doesn't produce any water. I have cleaned filter periodically.Sometimes I collect... (More)
Answer
totally shut down, no lights , nothing. It just quit as if someone pulled the plug. Is there a reset... (More)
Answer
My 1 yr old Haier HDN455 dehumidifier has stopped working, although the green "running"... (More)
Answer
d2 shorted do not knows specs to buy a replacement
Answer
what is zd2. Mine is shorted and I do not know the specs
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HDN455 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
