Question about Sony Ericsson P910a Handheld
Sony ericsson p910a cell phone
How do you remove the touchscreen because i try it and it seem if it's glue to it, but i'm not sure? thanks you
    Scholar:
  • 86 Answers
Hello. There's a special adhesive attached to the back of the touchscreen that allows it to be attached to the LCD screen. You will need to start prying it off the LCD screen very slowly, working from one corner and slowly peeling it back with the use of an x-acto knife, or other sharp-bladed knife. You must be very careful as it's very easy to permanently damage the LCD screen underneath. I suspect your touchscreen stopped working, hence the need to replace it. Good luck.
Posted on Apr 03, 2009
Touchscreen incoming call problem. HELP PLEASE!!!
My friend i have the same issue... It must be a coomon fault with the aino's... never buying sony Ericsson again!
Aug 01, 2010 | Sony Ericsson Aino Cell Phone
Puk code for sony ericsson p910a
Has anyone got a puk code for a sony ericsson phone. It is on o2 if that makes a difference
Apr 24, 2008 | Cell Phones
Sony-Ericsson P900 firmware files needed
Help me i need firmware update P910i
Apr 17, 2008 | Sony Ericsson P900
Touchscreen
I would like to ask a couple questions that might be of some use.
First, does the same issue occur when using the phone with the flip closed? That is, can you use the jog dial and keys on the flip properly?
If the phone works fine with the keypad and jog dial, then you should be able to try to recalibrate the touchscreen.
To re-calibrate the screen:
1. Select Applications tab
2. Select Control Panel
3. Select Device
4. Select Display or Screen
5. Follow the instructions on the screen.
6. Select Yes or No
Second, if you turn the phone off and on again, with the flip open, does anything load by itself, or does the touchscreen react as if something is being pressed?
This may indicate that there is a problem with the hardware.
It is possible to purchase a new touchscreen for under $100 from a few parts retailers such as http://cnn.cn .
It may also simply be a glitch or bug in the software or firmware OS. In this case, you can try a master reset or updating the firmware using Sony Ericssons update service (not compatible with Vista for the P910), or you could use a third party firmware utility such as from DaVinci etc.
If you choose any of the master reset, firmware or update options, you will lose ALL user data on the phone, so you should back it up before you proceed.
Apr 01, 2008 | Sony Ericsson P910a Handheld
Touchsrcreen is stuck in some mode.
3. Select Device
6. Select Yes or No
P990i: touchscreen stick borken into two pieces and stucked in the hole accidentely
If you still have the other half of the stylus, put a tiny spot of super glue on the end of it and push it in the slot. Wait 10 minutes and gently try to pull the complete stylus out. Failing that use a tooth pick, flatten one end and do the same as described above.
Go easy on the glue it's much stronger than it appears, you don't want to glue the whole stick in the hole.
Feb 03, 2008 | Sony Ericsson P990i Cellular Phone
Change Faulty/Cracked touchscreen on P900
The screen consist of two parts: touchscreen(TS) itself and LCD screen. They're attached mechanically, not with glue or solder.
TS glued to metal frame and by mean of this frame(mechanically) attached to LCD(like shoebox cover) - you can see pits on side.
1. With sharp blade of razor or scalpel gently remove this frame with TS glued on top.
2. Then remove TS from the frame (I simply broke it and removed glass pieces from the frame)
3. Clean the frame with alcohol to remove glue and grains of glass.
4. Glue new TS to the frame at ONE SITTING!
5. Wipe out dust from LCD and inner surface of TS and attach the frame.
6. Buy conducting glue and connect 4-contacts of TS cable with LCD cable. Put adhesive tape over them to maintain electric connection.
That's all.
Jan 28, 2008 | Sony Ericsson P900
I cannot switch on Sony Ericsson P910a
Hello. Please remove the battery form your P910 for about 20-30 seconds, reinstall the battery and then try to turn it on. If the red light remains on, then there's internal damage to your circuit board that will need to be properly fixed by a qualified technician.
Jan 01, 2008 | Sony Ericsson P910a Handheld
Sony Ericsson P910a Handheld Logo
96 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
