Question about Archos AV700 Digital Media Player
Archos av 700 shut off
If I have the battery still in when I turn off the av 700 then the hard drive keeps running..forever! I have to turn it off and keep it plugged in or take the battery off. Makes the unit no longer portable because by the time I get anywhere it has already discharged the battery if I leave it in the unit or I have to carry them separately.
  • fpna May 21, 2008
    If hardware reset and factory reset are the same thing, than I have done that a few dozen times. I have also updated the firmware without any effect.
  • Anonymous Aug 02, 2008
    my problem is that my Archos av 700 shut off soon as it is switched on
Do the factory reset.
Posted on May 21, 2008
Problem with the hard drive
your harddrive is have to reformat it
Mar 02, 2009 | Archos AV 700 160-Hours Video Recorder
Can't link my archos to my laptop
1. Copy all factory installed files from the Archos on to your PC hard drive or write a CD / DVD.
2. Download the latest software from and keep a copy safe (not on the Archos!) … there was a new version last week by the way …1.5.12
3. If you record any films, music, or TV that you want to keep forever then don’t keep them on the Archos!
4. Factory installed samples (photos & films), wallpaper, etc are available for download from FTP://
5. If you need to format the drive but it won’t talk to the PC through the normal USB, try plugging a flash memory card (the bigger the better) into the other (left hand) USB socket and copy stuff onto it.
6. Avoid changing back & forward between ‘hard drive’ and ‘windows device’ … not sure if this was the cause of the problem but you never know!
7.Always have mains power (not battery) when moving files around.
Nov 13, 2008 | Audio Players & Recorders
Archos av 700- Im having a problem with mine it keep coming up with can't read from hard drive error.
It only contains a laptop hard drive, so buy a new one remove all screws from either side of your av700 and replace it, dont worry cause once you open your av700 the hard drive is really simple to swap,then fire it up and format the drive you can download upgraded software from
Jul 24, 2008 | Archos Computers & Internet
Keeps shutting down.
The solution is found! There's no need to format your HDD
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Sound problem
Make sure that the sound cables are connected,If you are using the RED BLUE GREEN cables,they do not carry sound.You have to run a set of sound cables RED AND WHITE to the Archos from the cable BOX or whichever component you are recording from.Good Luck.
Dec 29, 2007 | Archos AV 700 160-Hours Video Recorder
AV700 wont even turn on
have you tried resseting the unit?
Dec 23, 2007 | Archos AV700 Digital Media Player
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Archos AV700 Digital Media Player Logo
475 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
