Question about Toshiba 23HLV87 23 in. LCD Television
23 inch diagonal tv/dvd combination model # 23hlv87
I need the code so I dont have to use two remotes for this tv. I had comcast out they said once I get the remote code I could enter into the comcast remote and would not need the toshiba remote anymore. Thanks Tom
  • 35 Answers
With comcast red ok select switch 11256, 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast grey ok select switch 0154, 0156, 0060
Posted on Jul 07, 2009
How do i set up my toshiba 23hlv87 remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 24, 2014 | Toshiba 23HLV87 23 LCD TV WITH BUILT-IN...
Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Apr 23, 2012 | GPX TV6000 9 in. TV/DVD Combo
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
Remote codes
There is another method for locating the codes for the device you wish to control. Although I do not know the specific remote model you have it should work. First though try any of the codes listed here that you have not already tried.
0002, 0179, 0184, 0209, 0236, 0463, 0479, 1479
On a majority of the Comcast remotes you have to follow special instructions for setting up combo devices.
For your TV/DVD.
  • Turn the device on and insert a DVD
  • On the remote press the DVD button once, then press and hold the Setup button until it blinks twice.
  • If you didn't insert the DVD into the player the first time you tried your codes, retry those as well. The most common code for your device is 0236
  • If you entered the code in correctly the DVD button should blink twice if not try it again.
You may also need to enter a separate code for controlling the TV for volume control.
If you still have not found a code that works then use this method to search the stored memory for codes.
  • Turn on the device.
  • On the remote press the corresponding Device key and it should blink once.
  • Press and hold the Setup key until the Device key blinks twice.
  • Now enter 991 on the key pad and the Device key should blink twice.
  • Aim the remote at the Device and press the Power button once.
  • Now press and release the Channel + button continuously until the device turns off.
  • Press the Power button and the devise should turn back on.
  • If the device does not turn back on then press the Channel - until it does.
  • To lock the code press the Setup button.
Again since I am unsure of which model remote you have there is a slight variation to this with other models.
Instead of pressing the Channel+ to scroll through the codes you need to alternate between the Power button and TV button.
If you still are no closer to relaxing while watching a DVD. You may want to consider programing the TV/DVD as separate devices.
All this seems like a real pain so good luck.
I hope this helps, but if not respond with the remote model# and maybe I can do more with that.
Oct 02, 2009 | Orion TVDVD092 9 in. TV/DVD Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Need code for my comcast remote
Comcast says that if the codes listed in the instruction brochure provided with the remote (10236 and 10463 for Broksonic) don't work, you should code 991 into the remote and then press the CH+ button repeatedly in order to search through the library of installed IR codes until the TV turns off, then press SET once to lock the code. This worked fine for me, although I must admit I had to press the CH+ button well over 100 times until I came across the proper code in the library to turn the TV off. Unfortunately, there is no way to know what 5 digit code this represents so that if I need to reprogram the remote in the future, I will need to go through the same time-comsuming process all over again.
Feb 20, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Toshiba 23HLV87 23 in. LCD Television Logo
297 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
