Question about Goodman CKL60AR60 Air Conditioner
NEC RIH 2667
I've had a RIH 2667 air conditioning and the heating mode doesn't work quite right. I've set the temperature at 25 and it will start the heating mode just fine for 15 minutes then the display number on the machine will start jumping up to 30 and above then stop from heating. The room temperature at that time was only around 20-21 degree. A technician came over and has determined that must be the indoor unit sensor and has changed it but the machine is still doing the same thing. Could anyone please tell me what is wrong with it?
    Guru:
  • 1,524 Answers
Circuit board
Posted on Apr 23, 2009
The heater in my excel blows cold air only . The dimist still works just no heat what should i look for?
There are several things that you can do about a heater blowing cold air, but if you keep running into problems then it might just be time to call in a heating repair company. If need be, here is a useful article on: HVAC installation cost, and how to get a fair price. How serious of an issue this is depends greatly on where you live. If you live in the north (Bozeman, MT, etc), then I'd recommend you have your furnace inspected annually to ensure that it is working properly. I'd also recommend that you install a backup means of heat...just in case. ASM has over 25 years of heating and air conditioning experience. If you have questions about a heater blowing cold air or any other HVAC related topic, try the ASM Air Conditioning and Heating Blog or if something your contractor is telling you seems expensive or doesn't sound quite right, consider using our Online Air Conditioning Consultation Service.
Jul 27, 2016 | Cars & Trucks
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
Why doesn't my heating and cooling system come on when i start the car?
If this is a new problem, a temperature sensor may have gone bad. But if this is a new car to you, some Climate Control cars work this way.
Some will allow for Vent or Panel just to get air circulating, but the A/C should come on when you select A/C unless the outside temperature is too low.
For heater functions, the engine must warm up enough to provide heat. The Climate Control models will not turn on until it compares your temperature settings with how hot the engine water temperature is to provide this heat for you.
Now you may need to check the Antifreeze levels and check the temperature of the Radiator water to know if the Thermostat is working properly.
Oct 16, 2012 | 2001 Oldsmobile Intrigue
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
I have lost my service Manual for my NEC 6847 Air con unit & need to download one so that i can figure out how to get the heat to work
Make sure the remote control 'Mode' setting is on 'Heat', usually an icon that looks like a small sun. Then increase temperature setting until unit switches on. Can take 7 minutes or so to give any warm air flow, but if nothing after about 15 mins, then you have a problem. - Rick
Jun 12, 2011 | Heating & Cooling
The heat in my 2006 grand prix will not get hot. We replaced the thermostat and got nothing. So I got the radiator flush and force filled again. Still nothing. Temp of the motor still gets to the middle,...
Are the 2 tubes that go to the heater core getting hot? If so, then the blend door is not opening to allow heat to get to the cabin.
Possible vacuum motor problem, either disconnected, or the controller for the blend door is broken is likely problem.
Troubleshooting by Symptom Poor Heater System Performance CAUTION
Check all fluid levels and adjust as needed, before operating vehicle for extended periods at idle.
  1. Start the engine.
  2. Idle the engine until the thermostat opens (upper radiator hose will be hot) Is the engine at normal operating temperature (approx. 200° F)? If yes, go to the next step. If no, go to step 16.
  3. Set the mode selector to FLOOR mode.
  4. Set the heater control selector to the warmest temperature setting.
  5. Set the blower speed the lowest setting.
  6. Carefully feel the inlet and outlet heater hoses at the heater core. Is the inlet heater hose significantly hotter than the outlet heater hose? If yes, go to step 14. If no, go to the next step.
  7. Set the mode selector to PANEL mode.
  8. Select the maximum blower speed.
  9. Select the warmest temperature setting.
  10. Place a thermometer into the center I/P PANEL air outlet and affix a second thermometer to the heater core outlet heater hose.
  11. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 13.
  12. Inspect and repair the cowl, cowl area, recirculation door, and the HVAC evaporator/heater core case for cold air leaks. Repair any problems found, go to step 17.
  13. Inspect the temperature door operation. Repair any problems found, go to step 17.
  14. Turn OFF the engine. Back-flush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Is the inlet heater hose feel significantly hotter than the outlet heater hose? If yes, go to the next step. If no, go to step 17.
  15. Replace the heater core. When the repair is completed, go to step 17.
  16. Check for low engine temperature problems, Repair or replace as needed, go to step 17.
  17. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Air Door Actuators/Motors Removal & Installation Recirculation Actuator To Remove:
  1. Remove the right lower instrument panel (I/P) insulator.
  2. Remove the glove box assembly. Recirculation actuator (Typical) gm-10-00-3695.gif
  3. Remove the mounting screws and recirculation actuator from the HVAC module assembly.
  4. Disconnect the recirculation actuator harness connector.
To Install:
  1. Align the recirculation actuator slots with the flats on the actuator door shaft.
  2. Install and secure the recirculation actuator on the HVAC module assembly with the mounting screws.
  3. Connect the recirculation actuator harness connector.
  4. Install the glove box assembly.
  5. Install the right lower I/P insulator.
  6. Calibrate the recirculation actuator.
Mode Actuator To Remove:
  3. Remove the mounting screws and mode actuator from the HVAC module assembly.
  4. Disconnect the mode actuator harness connector.
To Install:
  1. Align the mode actuator slots with the flats on the actuator door shaft.
  2. Install and secure the mode actuator on the HVAC module assembly with the mounting screws.
  3. Connect the mode actuator harness connector.
  6. Calibrate the mode actuator.
Air Temperature Actuator Right Side To Remove:
  2. Remove the glove box assembly. Air temperature actuator (right side) gm-10-00-4356.gif
  3. Remove the mounting screws and right air temperature actuator from the HVAC module assembly.
  4. Disconnect the right air temperature actuator harness connector.
To Install:
  1. Align the right air temperature actuator slots with the flats on the actuator door shaft.
  2. Install and secure the right air temperature actuator on the HVAC module assembly with the mounting screws.
  3. Connect the right air temperature actuator harness connector.
Left Side To Remove:
  1. Remove the left lower instrument panel (I/P) insulator. Air temperature actuator (left side) gm-10-00-4357.gif
  2. Remove the mounting screws and left air temperature actuator from the HVAC module assembly.
  3. Disconnect the left air temperature actuator harness connector.
To Install:
  1. Align the left air temperature actuator slots with the flats on the actuator door shaft.
  2. Install and secure the left air temperature actuator on the HVAC module assembly with the mounting screws.
  3. Connect the left air temperature actuator harness connector.
  4. Install the left lower I/P insulator.
  5. Calibrate the mode actuator.
Oct 18, 2010 | 2006 Pontiac Grand Prix
Unknown 2007 Toyota Camry Hybrid Button
The ECO HEAT/COOL button of your hybrid functions to reduce the consumption of electricity thus, a reduction of fuel consumption. An indicator 'ECO' appears on the air conditioning display to indicate that the mode is on. Of course, with the ECO HEAT/COOL on it'll take longer than the usual amount of time for the temperature to reach its normal or standard set temperature.
Your ECO HEAT/COOL mode won't function if your temperature control is set at 'LO" or 'HI" or if the air flow is in the "floor/windshield mode" or "windshield mode".
Hope this helps.
-jay
Jul 03, 2009 | 2007 Toyota Camry
Heat Pump
Your inside cooling coil in the air conditioning mode could be frozen over. Change the fan setting to on and operate it that way when in the cooling mode. Turn the air conditioning OFF with the fan ON to clear the coil of frost which should take about 1 hour.
The fact that you have sweat on the large line means that the temperature of the gas inside the line is below the due point of the moisture in the air. A good tech would measure the pressures and temperature of the system to get what is called superheat to determine proper system charge of refrigerant.
Jun 14, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
190 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
