Question about HP Photosmart C4280 Aio Printer
Printer malfunction Printer doesn't work. It's the second one in less than two weeks. HELP
  • William Park May 21, 2008
    Printer will only print page three no matter how many pages you want to print.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once remove the USB cable from the computer and refresh the spooler by performing the below steps if you are using XP os.
Click start >> run >> services.msc >> locate print spooler in services widow >> right click on it and select refresh or restart.
Now open the printers and faxes window from control panel and right click on the C4200 printer icon and click on properties >> advanced tab >> enable print directly to printer and click OK.
Now connect the USB back to the computer and try to print.
If the issue still persists then download and run the print diagnostic utility from the HP website and run it.
Posted on May 30, 2008
Malfunction detected screen appear
what is the malfunction code and would help to know the model of the machine
Apr 07, 2014 | Konica Minolta Office Equipment & Supplies
Hp 4620 printer doesn't print black ink
i have same problem and have tried everything suggested on HP website. I can print in color but not black and white
Nov 08, 2012 | HP Officejet 4620 All in One
Continusly red green lights on and no action
if the print dialog window indicates that there is a printer malfunction, check the printer for any possible paper jams, then check that the printer cartridges are inserted properly. close the dialog window, and press the blinking button on the printer.
if that doesn't work, restart printer: either press on/off button or unplug the printer. wait 15 seconds, then turn on/plug in the printer.
Oct 30, 2012 | HP LaserJet 1015 Printer
My acer aspire 3000 star up only half way and torn off in seconds ?
turn on your laptops, press F2, and wait for a while. if your laptop doesn't shut down, it means you just have a software problem, try to check the boot order. make sure you put your hard drive as your first boot order and save. if it still shut down even after inside the bios setup, it means your laptops have a hardware malfunction. probably overheat, exhaust covered by dust, the cooling fan is not working, or other hardware malfunction.
Jun 13, 2012 | Acer Computers & Internet
I have had this aficio 2022 for less than 3 years and have less than 20,000 copies. I only have used it as a copy machine . There is a printer parallel port . I've just connect it to my computer to...
Does the copier have a printer /scanner sd card installed and a network card installed in the machine as this is the best option to use the machine as a printer
Mar 11, 2017 | Ricoh Aficio 2022 All-In-One Laser Printer
When you plug it in, (lexmark pro 205), there is a white light in the display box but no words or pictures and the on button does not light up. the only way to shut it off is by unpluging. It does...
Try to rebrick your printer. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will give enough time for the printer to reset itself.
You may also try to plug the printer to a different known working power outlet in the wall to identify if it's a faulty power outlet issue.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark Prospect Pro205 Wireless...
There is a paper jam
The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
Mar 06, 2011 | Kodak Office Equipment & Supplies
Malfunction Printer
well try to reinsatll the printer driver and also chek for obstruction.if problem persist contact HP
Jul 12, 2009 | HP DeskJet 3550 InkJet Printer
Ricoh copier/printer error SC505
SC505 LCC Tray Malfunction (Optional LCC)
Remove the trays - reseat see if that clears it
Jun 19, 2009 | Office Equipment & Supplies
My Sansa doesn´t work well,
If it is still on, hold down the power button for about 15 seconds; that should turn it off. Try turning it on again. If it still does not work, turn it off by holding power for 15 seconds, then on again like this: - Put hold on - Hold record - Press power on This will start recovery mode, follow on-screen instructions. Hope all goes well!!
Apr 29, 2007 | SanDisk Sansa e250 MP3 Player
HP Photosmart C4280 Aio Printer Logo
Ben Johnson
