Question about Kodak Easyshare M753 Digital Camera
My optio was dropped with the lens going down first. now my camera makes noises & the screen is black. how do i go about fixing it?
Basically i was taking pictures with my friend, and on accident i dropped my camera with the lens going down first [it was turned on], it appeared to be alright, but it started to make noises, and now when you turn it on it goes to the OPTIO screen, and then turns black, and continues with the noises. How am i able to fix my problem? my friend was handing me my camera (turned on) and i accidentally dropped it. it looked fine except for the lens was dented in a little. this happened once before and it said lens malfunction. i pulled it out and it was fine so i did the same this time and then i just turned it off. when i got back to it though, after i turned it on, the screen is all purple and has lines and the picture won't show. i need serious help, PLEEEEASE!!! (all the functions work and i can see pictures i've already taken, so it is the lens for sure)
  • carlyb4 Jul 31, 2008
    i dropped my kodak easyshare M753 camera when my friend asked to see it and i thought she had it when i picked it up it was off.so i tried to turn it on and it said lens error and a whole bunch of numbers and i have no idea what to do HELPPP MEEE!
    Sergeant:
  • 284 Answers
Looks like the gears or retracting mechanics are damaged.
its problably not worth to take it in, to get it fixed (depends on the camera). but most likely sound like the gears are busted.
you be paying for repairs that costing waaay more than the camera.
Posted on Jun 05, 2008
I am getting a Lens error on my Pentax Optio 60 Digital Camera. How do I fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 19, 2011 | Pentax Optio 60 Digital Camera
My son dropped my Pentax Optio S12 now the lens won't retract and when I try to turn the camera on it just powers down and switches off
Your camera has a small chance of recovering from this very common fault: it's usually just caused by debris or dirt on the mechanism but in this case it will be either due to dislodged or broken components. You can try some of the fixes listed in this link , fix #7 is the one you're really aiming at but it's an all or nothing repair. Many retractable lens cameras have fragile zoom assemblies, but in my experience the Optio S12 has a poorer design in this respect that most and seems particularly prone to the fault.
If your camera shows absolutely no external evidence of having been dropped, then you may instead wish to see if Pentax will repair or replace it under warranty or even as a goodwill repair if just outside the warranty as it's just possible that they have identified a fault in design, materials or manufacturing of the lens unit. It would be best to say that the fault occurred out of the blue. if you choose this option, DO NOT make any attempt to fix this yourself. You also need to be aware that if Pentax judge that the fault was due to abuse (being dropped) they will offer to fix the camera at cost or will return it to you for a small fee. Given that the whole lens assembly must be replaced, and that you can buy a new replacement for around £100, you might decide that a paid repair makes no economic sense.
I sincerely hope that you get your camera working again and that you found my reply to be of use in deciding which approach to take. If so, please rate my answer.
Feb 25, 2010 | Aqua Pentax Optio S12 Digital Camera
My canon sd550 lens are not going down and when i try to take a picture it makes a funny noise and comes up with a blank screen
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Petax Optio E60 lens error of 0x15110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Pentax Optio E60 Digital Camera
Power keeps shutting down.
It sounds like you may have a bad lens assembly, but you did not mention if it seems to be fully extending or not. If it is sticking, it will usually buzz. If it fails to open all the way, it will turn itself back off. This sounds like what may be happening. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Oct 05, 2008 | Pentax Optio A10 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
186 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
