Posted on Sep 22, 2010
My Sony MHC 771 3 disc changer says there is no disc when there really are . It will not play any CD . Is there a sensor I can clean?
1 Related Answer
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Feb 11, 2009
SOURCE: sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
I have a Sony MHC-771 mini stereo system with a 3 cd disk tray. I need to replace the belt that operates the cd tray? The tray is stuck in the closed position. Any suggestions?
Remove the belt and measure it in MM. The search for a belt at that size with Google. You don't have to be too precise about the size. For example if it is 48mm than a 50mm belt should do the trick. Don't bother with the maker's name either. Then can be universal. As long as it looks right.
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
My Sony MHC-RX30 3 cd changer will not play-- It says "no disc" when there are discs present. Someone told me that the laser lens could be dirty- Any help would be appreciated
Hi Tom,
First of all, thank you for posting your question here at Fixya.com.
The symptoms you've described "No disc Error" is a fault when the optical lens failed to read the disc on its assembly. Yes, one caused of this symptoms is a dirty optical lens due to fine foreign object build-up on the optical lens itself like dust and static electricity build-up.
I would advice you to clean the lens using the CD disc lens cleaner. Play it at least two times to the unit to clean the dirt and static electricity build up. Most of this symptoms resolve by lens cleaning alone.
However, after playing the disc lens cleaner on the unit and still the symptoms persist, this is an indication that the optical lens is faulty. You have to replaced it with new one. Click it here for the replacement.
Before you replaced the optical lens, observe the disc if will spin or not upon playing, if yes then the problem is the optical lens, if not, the fault is on the disc assembly, you have to replaced the entire disc assembly. Contact this LINK to inquire for the parts.
Hope I helped you.
Have a nice day!
Good luck and take care!
Rating and feedback are highly appreciated.
Kind Regards,
Mjsazon
I have a Sony MHC-GX470 stereo...it will not play cd's...when you load a cd in it comes up with "mecha error"...the cd changer will not move between cd 1, cd2 and cd3 either.
the mechanism is bad or in human terms the motor that excepts and moves the disc has gone out i reccomend taking it to a repair shop to get a estimate because it may jus be cheaper to replace it.
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
1helpful
No disc
clean the laser lens maybe got some dust good luck
2helpful
2answers
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
2answers
Defective sony vcd Model MHC-VX33
If it havent been use for a long time try dusting it and cleaning it first, sometimes dirt gets stuck on vital places which makes it go crazy. Hope this works. Please dont forget your rating for me as well...We take time in answering problems. Thanks
3helpful
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
