Question about Kirby Ultimate G Bagged Upright Vacuum
Belt knob on/off position - does not lock
when I turn the lever / handle to put the belt in the off (red arrow to red arrow) position, it does not lock into place. Any suggestions?
  • laurensegal May 21, 2008
    I should have clarified. The head? did not stay in the Belt Off position when it was off the machine. Once I put it on the vacumm itself, it stayed in place.
    President:
  • 1,673 Answers
If it doesn't lock, then maybe you haven't turned quite far enough. Could also be that the belt is so stretched, that it isn't holding in the locked position.
Posted on May 21, 2008
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
I can't change the belt on my Ultimate G Diamond Edition
You have to take the nozzle off. Then twist the handle to OFF position to catch and stretch the belt, put the nozzle back and then twist the knob to ON.
Instructions with pictures HERE
There is video manual on the front page on goodvac.com too...
Good Luck,
Rocky
Mar 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria belt install
Make sure to follow this sequence (starting from the nozzle off and green arrows on the knob and label matching):
1. Turn the knob all the way to match the red arrows (make sure that as you are doing so the hook inside of the nozzle hoes through the belt and stretches it - you will feel that knob is prettu hard to turn)
2. Put the nozzle on the unit and fix it in the place with the latch.
3. Turn the knob back to match green arrows
There are some more detailed instructions and pictures on goodvac.com
YOU'RE DONE
Oct 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Belt not locking
With the nozzle off of the vac., turn the big knob on the front until it locks. (will only turn one direction) Put the nozzle back on the vac, lock it down, turn the knob again and the belt will be on the spindle and you should be set to go. I hope tho that you put on a new belt, they stretch after a short time and will start slipping under load.
Jun 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Brush Roll won't switch positions
The adjustment knob on the hood of the machine is a plastic "arm" that prevents the belt tensioner from tightening up the v-belt so that the roller will stop or start. If the knob is adjusted while the handle is back, it can break the plastic arm off and then the function will not work. This knob should only be adjusted with the handle in the upright position. Usually, if the arm is broken, the roller will still turn when the handle is lowered and will not turn off when the knob is selected to the bare floor. If the brush roll will not switch on , it is usually a problem with the belt(s). You should replace the belts yearly. They can look fine, but be worn out.
Dec 14, 2007 | Hoover U6630-900 WindTunnel Bagless...
Belt replacement
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Jun 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Attachment probs
Hi- Do you have a manual for the vacuum? My manual says to raise the headlight hood and then flip out the l-shaped handle on the belt lifter and turn it until the red arrows line up. Turn the accessory lock all the way to the left and the front should lift off. Then take the attachment hose and hook the two hooks over the bar and then push the hose up against the vacuum and lock into place by turning lever to the right. Does this help? Its kinda hard to explain without the pics.
May 19, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
121 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
