Question about Samsung Digimax S500 Digital Camera
Digimax S500 I get 3 beeps and lens is stuck is ther a solution to correct this proble?
The lens stays in the outmost position although batteries are fully charged. This has happend twice. The first time I had a valid waranty so the problem was fixed for free. Now it has happend again and there seems to be no way to get the lens back into the camera. Also the display is totally black.
I guess I have taken about 500 pictures since the last repair. Not very much - even a cheap camera should last for longer than that.
Never Samsung again!!!
Posted on May 25, 2008
Samsung digimax d53 beeps then shuts off with lens stuck out
The camera lens is jammed, caused by dirt or worn out gears. a camera technician would be solution but not cheap, or you can take matters in your own hands and try a risky trick "NOT RECOMMENDED" take the palm of your hand and sharply hit it around the lens housing and applying power as you do so in an effort to get lens to retract, if you are lucky it will work or make things worse.
Mar 10, 2012 | Samsung Digimax D53 Digital Camera
My s800 camera wont turn on or it does but the zoom/lens is stuck and wont come out-it then has 3 beeps and turns off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
Lens stuck in out position, beeps 3 times then off.
Just had same problem with mine, I wiggled/turned the lens a couple of times before turning it on, and it popped out of the stuck position and closed again. It's working - but clicking when I move the lens in or out.... :(
Jun 09, 2009 | Samsung Digimax S700 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
Samsung Digimax D53 beeps and shuts off
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on and everything was working again ! Whew ! Problem Solved :D Good luck!!
Mar 15, 2008 | Samsung Digimax D53 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
149 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
