Question about Zyxel Prestige 660R Router (91004397002)
No DSL or Internet light
I have a Zyxel P600R-D1 dsl modem that's hooked up to an Airport Extreme via ethernet cable and can't get on the internet as of 3 weeks ago. No dsl light or internet lighting up on the box. I am a MAC user using Earthlink home pkg including home phone/internet and the home phone works perfectly fine.
Earthlink thinks it's the wiring in the house. Local electrician thinks it's a faulty Zyxel router. This is the 3rd non working router Earthlink has sent me.
Thanks,
John
  • 2 more comments
  • wolfnipple May 23, 2008
    I understand dial up as an option but being that I've had dsl for a few years now and I'm paying 60 bucks a month for a whole pkg deal, I'd kind of like it to work the way it's supposed to.
    I've considered buying a router from Best Buy or something like that and see if it works.
    This might be a case of faulty equipment?
  • leaalissa Feb 09, 2009
    I have a Zyxel P660R-D1 dsl modem that's hooked up to an Airport Extreme via ethernet cable and can't get on the internet using airport extreme. but i can connect hard wired to modem.
    Need internet sharing. how do i make my airport extreme connect to internet through the zyxel p660r-d1 modem?
  • Anonymous Mar 21, 2014
    dsl light blinks and no internet access
    dsl light keeps blinking and will not access internet
  • 298 Answers
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
Posted on May 20, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 25, 2008
    that is also one good option to tell which one is causing the problem.
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Airport Extreme, Mac Cube and proposed Blue Ray /WIFI
    Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
    Here's a quick setup guide from Apple.com:
    Setup Airport Extreme
    Jul 23, 2010 | Apple Computers & Internet
    Just got a new router (motorola) and airport will
    Check your connections:
    DSL-modem to telephone-jack (or cable-modem to cable-jack).
    Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
    Ethernet cable from LAN port on router to WAN port on your Airport.
    Cut the power to the Airport, and then plug it back in, so that it restarts.
    Apr 17, 2010 | Apple AirPort Extreme Router
    Describe your zyxel p-600 dsl light turns off then on
    Hello kb_gimper,
    The power light and all other lights blink when the ZyXel P-600 is initializing. The ethernet, dsl and internet lights blink when data transfer is detected. The lights are from left to right:
    * Power Light
    * Ethernet Light
    * DSL Light
    * Internet Light
    If this solution is helpful please click a thumbs-up rating below.
    Have a great day,
    martyshaw152
    Dec 19, 2009 | Zyxel Prestige 660R Router (91004397002)
    Ethernet to router connectivity issue
    The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
    Dec 01, 2009 | Zyxel P660HW-D1 Router
    Modem won't connect to internet. OS: WinXP Pro SP 3. ISP: Earthlink DSL. Modem: ZyXEL P-660R-D1 (supplied by Earthlink) connected to computer with ethernet cable. Modem includes double filter for phone...
    maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
    Jun 19, 2009 | Computers & Internet
    Wireless connection fine but internet connection impossible
    if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
    hope this'll help you
    ciao
    Nov 10, 2008 | Zyxel Prestige 334 Router
    ZyXEL adsl wirless modem router P660HW
    To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
    Jan 08, 2008 | Zyxel P660HW-D1 Router
    Router reboots when ADSL comes online
    I have not seen this issue before and I work directly with this modem on a daily basis. If its under warranty, then get a replacement. If not... Test the modem with wireless enabled, but wireless security disabled.
    Dec 27, 2007 | Zyxel P660HW-D1 Router
    Zyxel Prestige 660R Router (91004397002) Logo
    2,189 people viewed this question
    Top Zyxel Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
