Question about HP Photosmart C6280 Printer
Having trouble trying to figure out how to get the paper set.
I need to print a large amount of 5x7 cards, but I can not figure out how to get the paper set right so that it is centered on the card. Help, anyone with knowledge of this new technology.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
As this card is not suppourted by the all-in-one. We need to manually set the size of the card in custom settings under print settings in HP Solution center. Also choose paper type as plain paper and click OK.
After entering the size of the paper and giving it a name, once close and reopen the solution center and then select the name which we have given to this size and click OK and try to print.
Posted on Jun 03, 2008
Print set up in the program
You do not specify what Epson Printer you are using. I have an Epson WorkStation. The Document Format in the Principal (Main) tab of the printer parameters lists among other format, a personalized (custom) format where you can choose the dimensions in mm or inches.
Nov 22, 2013 | Arts & Letters Arts and Letters Express
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Size of page printed small
Check your default paper size on both the document program you are using and the printer. You could have it set for 5X7 and that's what it will figure for, even with 8 1/2X11 paper.
Jan 30, 2009 | Canon i850 InkJet Photo Printer
Want to print 3 different 5x7 cards at one time
Set the layout in the screen (according with the layout of the paper / cards you are going to use) --> set the 3 different texts (receipes) in the screen according with this layout--> print
Nov 02, 2008 | Broderbund PrintMaster Gold Version 18
How do I print on a 5x7 foldable card?
On your windows desktop, left click on START. Left click on CONTROL PANEL, then left click on PRINTERS. RIGHT CLICK on your printers icon. From the drop-down menu, left click on PRINTING PREFERENCES. You can now set up printer for the paper size and type you need.
Aug 18, 2008 | Office Equipment & Supplies
Problem printing business cards
I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP Photosmart C6280 Printer Logo
234 people viewed this question
Ben Johnson
