Question about Singer 3116 Simple
Thread tangles around shuttle
Same as everyone else.. It is a brand new machine. Used 3-4 times. rethreaded, tried everything. the thread is going around the outside of the bobbin case and tangling and making a thread mess on the underside of the fabric.
  • 323 Answers
Either the thread is not in the take up lever or it is not in the tension. Rethread the machine. Raise the presser foot and pull on the thread between the tension and take up. It should be loose. Lower the presser foot, pull on the thread between the tension and take up lever. It should be tighter. Make sure the thread is in the slot of the take up lever and pulled to the front of the lever.
sewman7
Posted on May 22, 2008
Singer Futura XL-580 thread tangles on underside.Machine makes a loud "clicking" sound.Was doing free motion quilting and got a jam. Changed needle,changed bobbin,and rethreaded both top and bobbin.
Sounds like there might be some thread stuck in the bobbin shuttle area. Refer to the users manual for your machine to see how to disassemble the bobbin shuttle and race to check for thread. It would be a good idea to put a drop or two of sewing machine oil on it while you have it apart.
Aug 21, 2017 | Singer Sewing Machines
What's wrong with my Nelco 234F sewing machine. When I try to sew, the machine gets jammed and the thread is all tangled around the bobbin.
Install a brand new needle.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Generally, the top tension should be set at the midway point and then tweaked for your particular machine.
If you continue to have a problem, the machine probably needs service.
May 09, 2017 | Sewing Machines
What is happening when I sew and 3 threads come out of the bobbin? Or when it just freezes up and I can't get the needle to go up or down?
basically the problem comes from incorrect thread tensions
the main thread responsible is the needle thread as the tension is far too loose
tighten up that tension and it makes the needle on the up stroke pull the thread around the bobbin carrier and collects the bobbin thread and pulls it up to the material
with the needle thread too loose the needle thread is wrapped around the bobbin carrier again giving you the 3 threads ( 2 needle threads and 1 bobbin thread and the tangle jams the bobbin movement
Sep 29, 2016 | Sewing Machines
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
Machine will not pick up bobbin thread. The bobbin wheel does not move, and when the top thread sweeps down it gets tangled in the hook and stuck. My machine is not very old and was working fine until this...
Sounds like timing of hook/needle. The needle should go down, a mechanism in the bobbin area moves to sweep the top thread around to pick up the bottom thread. Suggest taking it to a service technician, preferrably one authorized to repair your brand of machine. Check website for your brand and it might list authorized dealers close to you. Good luck.
Sep 24, 2009 | Singer Sewing Machines
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Jammed thread.
    To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
    Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
    are u talking about 3-4 uses from being a new machine or is this a machine you aquired,,,,alot of times the machine can be off timing, if this is not the case always try fully unthreading and rethreading and please use rayon or polyester thread, plus make sure you have the bobbin case in correctly
    Jan 20, 2008 | Singer 3116 Simple
    Singer 3116 Simple Logo
    182 people viewed this question
    Top Singer Sewing Machines Experts
    Tally Girl
    Tally Girl
    mystery_soul
    Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
