REMOVE**** FRONT SHOCKS, FIRST OF ALL.SUPPORT THE LOWER CONTROL ARM WITH A JACK,REMOVE FRONT WHEEL, REMOVE BRAKE HOSE AND ABS SENSOR HARNESS TO THE STRUT BOLTS OR CLIPS,REMOVE ACTUATOR FROM TOP OF THE STRUT,IF EQUIPPED WITH AUTOMATIC ADJUSTING SUSPENSION. PAINT ALIGNMENT MARKS ON THE UPPER STRUT MOUNTING BLOCK AND STRUT TOWER AND ON THE LOWER STRUT MOUNT TO STEERING KNUCKLE SO THAT CAN BE REINSTALLED IN THE SAME POSITION. REMOVE UPPER STRUT MOUNTING NUTS, REMOVE THE STRUT TO KNUCKLE BOLTS,REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT INTO THE STRUT TOWER ALIGNING THE PAINT MARKS MADE DURING REMOVAL.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 34 - 46 FT LBS. INSTALL STRUT TO KNUCKLE BOLTS TIGHTEN TO 55 - 61 FT LBS. INSTALL ACTUATOR AND ENGAGE THE ELECTRICAL CONNECTOR IF EQUIPPED WITH AAS. INSTALL BRAKE HOSE AND ABS SENSOR HARNESS CLIPS OR BOLTS.INSTALL WHEEL AND CHECK ADJUST THE FRONT END ALIGNMENT. TO ( REPLACE REAR SHOCKS ) REMOVE REAR WHEELS, REMOVE REAR PACKAGE TRIM. REMOVE SPEED SENSOR HARNESS, REMOVE TOP STRUT NUTS,THE SUSPENSION WILL DROP WHEN THE WEIGHT LIFTS OFF THE WHEELS. REMOVE BOTTOM STRUT BOLTS.REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT ASSEMBLY, INSTALL BOTTOM STRUT MOUNT BOLTS AND TIGHTEN TO 55 - 61 FT LBS.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 33 - 46 FT LBS. INSTALL SPEED SENSOR HARNESS.INSTALL REAR PACKAGE TRIM. INSTALL REAR WHEELS.
