Question about Sony VAIO VGC-RB50 PC Desktop
System Restore I can't use my system restore just stop work. It will start to work then in a minute or so I get a message that tell it can't restore. Can anyone help me? Thanks butbut
  • ritzy4runner Apr 08, 2009
    Same issue when I try to restore the computer to a previous restore point, will not let me, can't find one etc.
    President:
  • 2,712 Answers
Have you set up a previous restore point? If yes and you are still getting the same error, thn you may have to reinstall the OS..
Posted on May 20, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Everytime I start my pc up it reads files are compressed
Is it affecting your computer from running>???
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
You might use the system restore to restore your system to an earlier time click start all programs
If it is a hardware issue the system restore might not work
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Nov 22, 2013 | Systemax Computers & Internet
Watery Desktop 3d -Failure
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Jul 13, 2013 | Computers & Internet
Gateway desktop critical error code
Which operating system ???
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
System restore does not work vista
System Restore does not work? Why not? What type of message are you getting?
Were there any Restore Points created?
Are we talking System Restore or System Recovery (to factory settings)?
System Restore works within the windows environment and does not cause you to lose any data. You get it started by clicking Start/Programs/Accessories/System Tools/System Restore and then select a Restore Point (date and time) before you started having problems. It does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected).
System Recovery on the other had deletes everything. It sets your system back to the point when your first purchased it. Most times you need to read the manual on how to get the Recovery started. Hopefully you have a Recovery Partition on your hard drive that was setup by the manufacturer because trying to recover from disks that you created don't work most times.
May 12, 2012 | Computers & Internet
When my PC (PB iXtreme i7151B with Windows 7)goes on power save (asleep) when it is left alone for a while, it doesn't restore the desktop anymore when I get back on it. Only the background shows, and I...
i have reviewed your issue and read several articals in regards to this issue and it looks like it is common. I found one site that seemed to have the most details options and step by step instructions for different possibilities follow this link: http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
But prior to going into anything to technical, to me it sounds like it might be a software glitch with the operating system. In which case I would start by trying a system restore to a prior date when you know this issue was not happening.
System restore instructions are below:
Here's How:
  1. Navigate to the Start -> All Programs -> Accessories -> System Tools program group.
  2. Click on the System Restore program icon.
  3. Click Next > on the Restore system files and settings window.
  4. Choose the restore point that you want to use.
    Note: Check the Show more restore points checkbox to see more than the most recent restore points.
    Note: Any restore points that you created, scheduled restore points that Windows 7 created, and those created automatically during the installation of certain programs will be listed here. You can not use System Restore to undo Windows 7 changes to a date that a restore point does not exist.
  5. Click Next >.
  6. Click Finish on the Confirm your restore point window to begin the System Restore.
    Note: Windows 7 will shut down to complete the System Restore so be sure to save any work you might have open in other programs before continuing.
    Important: System Restore will not revert any of your non-system files like documents, email, music, etc. to a previous state. These types files are completely unaffected by System Restore. If your intention with this tool was to recover a deleted non-system file, try using a file recovery program instead of System Restore.
  7. Click Yes to the Once started, System Restore cannot be interrupted. Do you want to continue? dialog box.
  8. System Restore will now restore Windows 7 to the state that was recorded in the restore point you chose in Step 4.
    Note: The System Restore process could take several minutes as you see the "Please wait while your Windows files and settings are being restored" message. Your computer will then reboot as normal when complete.
  9. Immediately after logging in to Windows 7 after the reboot, you should see a message that System Restore completed successfully.
  10. Click Close.
  11. Check to see if whatever Windows 7 problem you were troubleshooting has been corrected by this System Restore.
    If the problem still persists, you can repeat the steps above and choose another restore point if one is available.
    If this restoration caused a problem, you can always undo this particular System Restore.
Aug 02, 2010 | Packard Bell Computers & Internet
My Acer Arcade no longer plays files???
You can restore your system to the earlier healthy state by following these steps :
1. Goto Start >> Programs >> Accessories >> System Tools >> System Restore.
2. System Restore window will appear. Click on Next.
3. A list of all available Restore Points will be displayed.
4. Select any Restore Point of your choice, and click Next.
5. Now, confirm the Restore operation by clicking on Restore / OK / Finish.
6. The System Restore process will take about 15-30 minutes.
7. Don't try to cancel or stop the process by pressing any key!
8. Don't turn off the system till the restore is done!
9. When the System Restore will be completed, a restore successful message will appear!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Computers & Internet
I want to do a system recovery on a EL1200 emachines? Could someone tell me how to do this?
I work with these machines every day, this model was designed after Acer bought out Gateway(who owned Emachines).
If you provide me an email address I will send a copy of the recovery disk creation instruction that we give to all our customers to you. Then once you have made the disks you can simply put disk one of the factory restore set in the DVD drive, Power down and restart and it will boot from the restore disk and from that point on you just have to confirm and agree with the warnings from the restore program to allow it to wipe the drive and start fresh.
Hope this Helps,
Chris
May 13, 2009 | E-Machines eMachines Desktop PC
System Restore
The system came with a hidden partition on the hard drive that can restore the system to factory default. If this does not work it means the partition has been damaged and you will ned to get the recovery CDs. Please note that you will lose all data unless you back it up first.
This is the process:
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish. When the restore process is complete, the following message will appear: The system recovery process was successful.
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Booting problem
If the computer was working properly few hours/days back... then you can try it by restoring the windows to an earlier time by booting it in the safe mode.
How to go in the safe mode < click
How to restore the system>
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want then its recommended to repair the windows.
Dec 04, 2008 | Dell OptiPlex GX260 PC Desktop
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Sony VAIO VGC-RB50 PC Desktop Logo
100 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
