Question about SanDisk Sansa e200 MP3 Player
Rolling Sandisk screen when connected to PC
Recently I purchased a Griffin PowerDuo external power supply to charge my Sansa e250. When I plugged in the AC power Duo to my e250, the unit powered on, and the Sansa screen started to roll. I immediately unplugged the power device, and had to reset the e250 to shut it down. Since this incident my PC's don;t recognize the device, and it never gets past the rolling Sansa screen. Any ideas what happened, and how to fix it?
  • 8,596 Answers
The voltage was too high, which jacked up your player. Try the following methods, but there is no guarantee they will work since that circuit is probably fried. Next time, just plug it into the computer to charge:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
PC does not reconize sansa 250
plug it in after you log on to your computer and wait for all the pop ups to go away then plug it in
Nov 25, 2009 | SanDisk Sansa e250 MP3 Player
My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Jul 30, 2009 | SanDisk Sansa e250 MP3 Player
My SanDisk Sansa e250 MP3 Player is messed up.
sounds like a defective battery i would consider purchasing a new one, i have the same player ive never had that problem but these players are a bit dickey with computer connections
Apr 06, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 Connecting Writing
is there a charger (cord plugged into the base) plugged in?
Jul 29, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
Sansa e250, will not charge...
when you unplug it try holding the power button for 20 seconds or more.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3 player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
