About 5 weeks ago, my 42" sanyo hdtv seemed to drop an octave or so, on all channels and when using a dvd... Yesterday it developed a "Vibratto", almost like a Reverb Channel on my amplifier.. Is there an easy fix, or do I have to return this to Walmart under a three year warranty.. Purchased 7/18/07 Ray English
  • 8,617 Answers
I would let them know that you need the set repaired or exchanged under the warranty. because if you remove the rear cover you will void your warranty
Posted on May 20, 2008
I have a Panasonic TH-58PZ700U Which drops channels? Will have the channel one day and the next its gone then it will reappear! Is it the tuner going bad?
I would replace the DG Board. There hard to come by for this TV. I saw one on eBay about a week ago for $75.00 witch is a very good price for this part.
Jul 03, 2014 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
I have a Sanyo 42 inch Mode Number: DP42647. I bought it 2.5 years ago, and suddenly, the video is out. The sound is ok, as well as the "power" green LED. By looking at other forums, it seems...
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
May 20, 2017 | Sanyo 42 in. LCD TV
About 2 weeks ago my dell 42" plasma started
this problem is from power supply section, check your power supply, change it with new one
Jan 16, 2011 | Dell W4201C 42 in. Plasma HDTV
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
May 13, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
My lg 32lc7d remote wont program the codes
you don't hold down the DVD button; you need to hold down the MENU and mute buttons simultaneously for 2 secs.
The LG owners manual doesn't seem to list a program code for Sanyo DVD players though, only Sanyo VCRs :(
Jan 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
