Question about OKI C5100n Laser Printer
Paper jam in HP deskjet 380 series
Had a paper jam but had the paper removed by pulling it out but still it wont print
  • Anonymous Jul 30, 2008
    printer won't scan or print
  • bridgengrx Aug 02, 2008
    I had a "380: Paper Jam / Open Front Cover" message. I opened the front cover and removed the jammed 8 1/2 x 11 piece of paper. When I closed the front cover, I still get the same message and the printer won't print. I then repeated the steps again twice, and still the message remains. Is there some sort of internal reset switch that must be reset?
  • 14 Answers
I just completely took apart my front feeder unit because I just didn't believe there was a paper stuck in there. Sure enough, when I got to the bottom (an hour later) there it was- and it wasn't from the paper that was jammed. It must have been floating around in there waiting to get in just the right place to block the little sensor wiggly thing.
After I got it out, I realized there was a MUCH easier solution--- get some heavy paper (I used cardboard folded in half) and manually feed it through the paper feeder in the front assembly by hand. You can see where it should go in (it's where the paper from Tray 1 goes in) and out (it lines up with the belt in the main body of the printer) and there is a large gear on the side you can turn to help you get it through (just turn the gears until you feel the one that grabs your heavy paper.)
As it comes out, it should have your stuck paper with it.
Jeremy
Posted on Jun 15, 2009
  • jerm01 Jun 15, 2009
    Okay- sorry about the last Solution I posted for this. I meant for it to go under "Oki 5100c" 380: Paper Jam but it's here now and I don't know how to move it/edit it/delete it.
    In any case, a strong paper in the right spot should clear just about any jam in any printer with a paper feeder that you can't get into. The instructions about "Tray 1" and "the Belt" are specifically for an OKI 5100C
Strip the front paperfeed, labels get stuck behind the presure rollers on the mp. one of the three sensors get stuck.
Posted on Feb 11, 2009
How to Fix Paper Jamming Issue in HP Printers?
not sure if this helps...
Skip to the two-sided printing accessory section if you have a two-sided printing accessory instead of a rear access door.
  1. Turn the knob on the rear access door counter-clockwise.
  2. Remove the door. ...
  3. Pull the jammed paper out of the printer. ...
  4. Check to make sure no scraps of paper are stuck in the printer.
More items...
HP Deskjet 900 Printer Series - Clearing a Paper Jam ' HP® Customer ...
https://support.hp.com/us-en/document/bud09128..
or go to this link...
How to Fix Paper Jamming Issue in HP Printers Google Search
Oct 27, 2017 | HP Office Equipment & Supplies
HP Deskjet D4100 1) The arrow pointing down near the power switch is flashing. Printer will not print. 2) The printer goes "offline" Paper is not jammed, have unplugged/plugged. rebooted numerous...
First, here is a link for the troubleshooting your printer: https://support.hp.com/us-en/product/hp-deskjet-d4100-printer-series/501868
I always go the the manufacturer website to download drivers. I also just had a similar problem on our printer at church. Two people looked and looked after pulling a jammed paper out of the printer. I looked a few times, opened the 2 back doors, the front door, removed the paper trays and looked, opened the side door, and looked again. Each time the printer said jam. I got a flashlight and looked everywhere again, nothing. Still said jam. I looked one more time in above where the paper trays go, and under a piece of plastic just barely visible at just the right angle was a tiny scrap of paper, not much bigger than a quarter. I managed to get it out and all works fine. Possibly you may have something like this going on?
Dec 22, 2017 | HP Deskjet D4100 series
I have use the HP Deskjet D1360 series printer paper jam
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
May 24, 2010 | Office Equipment & Supplies
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
I cant print
i need software for my hp deskjet 3745 printer
Oct 21, 2008 | HP DeskJet 3745 Printer
Paper jam wont print
hi dear
you have an old printer, but still oke, take care, to open the back panel from your printer
pull the jamming paper, and make it clear with self test
oke
Apr 06, 2008 | HP DeskJet 640c InkJet Printer
HP Deskjet 380 - wont print
I ran one copy of an email of one page and forgot to load paper so now the printer runs ok but the black and white and color are hardly readable they are so light.
Jan 12, 2008 | Office Equipment & Supplies
OKI C5100n Laser Printer Logo
476 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
