Question about Sony Computers & Internet
Blue Screen - indicating a problem
I keep getting a blue screen which reads:
Problem has been detected and window has been shut down to prevent damage.
If this is the first time...
Follow - check to be sure you have adequate disk space.
If driver is identified in the stop message. Disable drive and check with manufacturer for updates.
Try changing video adapters, chek with hardware vender for any bios updates, disable bios memory options such as caching or shadowing.
If you need to use Safe mode....
Technical info is ***stop: OXOOOOOO8E (OXCOOOOOO5, OXA89DA1D2, OXA8C7EA4C, OXOOOOOOOO) *** SYMSW.SYS - ADDRESS A89DA1D2 BASE AT A89C600, DATE STAMP 432EFFE1
BEGINNING DUMP OF PHYSICAL MEMORY. PHYSICAL MEMORY DUMP COMPLETE. cONTACT SYSTEM ADMIN OR TECH SUPPORT
  • 1 more comment
  • Martzme May 20, 2008
    XP home
    XP Home - NO CD
  • Brian Canute May 11, 2010
    are you running xp homr or pro and do you have your operating system cd reply back and will give you instructions
    Brian
  • 56 Answers
You possibly have a restore partition on your drive can you borrow a xp home cd from a friend if so let me know
Brian
Posted on May 26, 2008
    Genius:
  • 2,785 Answers
Your problem may be due to so many reason you have to check your ram the check your hard drive then you disconnect your optical drive, you have to do it one after one and see which is giving problem, if still you have problem plz post for futher assistance.
Posted on May 22, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
Blue screen
Yes normally if you don't shut down your system properly you get this message, Solution : Log on to save mode and backdate your computer to the day before you got this message. If it doesn't work, you are gonna need to reinstall your O.S.
Feb 07, 2012 | Dell Inspiron 710m Notebook
A blue screen appears when i turn on my computer.... sayin "a problem has been detected and windows has beed shut down to prevent damage to your computer."
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
If this answers your question, I would appreciate 4 thumbs
Sep 15, 2010 | Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
BLUE SCREEN; AutoFocus " UNMOUTABLE_BOOT_VOLUME "
Unmountable boot volume is an error you get when your hard drive is failing. You will need to replace the hard drive.
May 21, 2009 | Toshiba Satellite L35-S2366 Notebook
Blue screen ,technical info,
try reinstalling windows
Apr 02, 2009 | Computers & Internet
Shut down of laptop after blue screen appears
When you hit F12 or whatever F key to go to the boot drive menu, make sure the cd is in and that you select CD/DVD Drive and the dvd should prompt you to hit any key or will automatically start loading for the recovery. Just tell me if you need further assistance.
Feb 01, 2009 | Toshiba Satellite A135-S2386 Notebook
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
369 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
