Question about Vev Vigano Kontessa Inox 6-Cup Espresso Machine
Mine just started to leak
Out of the blue, and so I changed the rubber gasket, but it's still leaking
It's the 6-cup Kontessa
Any ideas why?
Thank you
  • jlcsg Jul 01, 2008
    Call this number and ask for Heather - she's very helpful:
    My pot started leaking out of the blue - could be you're using too fine a grind, or that the gasket is old. or that the gasket / filter is not put together porperly.
    But call Heather to be sure.
I have found this site for advice and parts for the stove top Espresso makers.
Posted on Jan 17, 2009
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 07, 2013 | Coffee Makers & Espresso Machines
My Waring Pro Coffee maker leaks water out of the bottom. In the morning when I get in I have to clean up the leak. Is this repairable?
When you pour water into the screen area it travels toward the back of the unit and drops through a rubber gasket/cup to be heated/processed. I have the same problem and while I bought another WC1000 I took my old one apart. By turning it over and removing 4 recessed screws you can carefully lift the top off (carefully because wiring is attached). However, you can now access the rubber gasket/cup. Doing this I found that mine was torn which I must assume is the cause of the leaking problem. Now if anyone knows where I can get a replacement rubber gasket/cup or a part number I would appreciate it.
Aug 22, 2010 | Waring Pro WC1000 Coffee Maker
I need a filter or a round rubber that has come on done-t vegano
go to
and then click on the small envelope in the upper right hand corner and send them and email - they can get you a replacement
Jun 22, 2010 | Vev Vigano Kontessa Inox 6-Cup Espresso...
I need to buy a vev replacement rubber seal for my stainless steel stovetop espresso machine
go to
then click on the small envelope on the upper right hand corner and email them with your question
May 20, 2010 | Vev Vigano Kontessa Inox 6-Cup Espresso...
Good evening! I have received the  Kontessa  Vev Vigano  12 cup from my family  but I don't have an  instruction book with it..  is there a  place where I can download  some simple instructions as to how...
You could use any Bialetti or Vev Vigano instructions created for aluminum pots. I have a 6 cup Vev Vigano Kontessa Inox, but the instructions that came with it were standard. Remember to use correct measurement of water and coffee. Coffee grind should be espresso. I don't know about 12 cup, but assuming that it's double of the 6 cup size, I use 9 oz of water and 6 tablespoons of espresso grind. You could go to Their customer service is pretty efficient. Even if you didn't buy your pot from them, they'll reply usually within 24 hours. Good luck.
Jan 02, 2009 | Vev Vigano Kontessa Oro 12-Cup Espresso...
I need a new funnel for my vev vigano kontessa 6 cup stove top espresso
Usually most stove top espresso makers manufacture these parts to the same standard. Take your old funnel, go to a kitchen store where they sell Bialetti, and compare their funnel size to your funnel size (for the same size put). I noticed that usually, it's the rubber gaskets that may differ slightly. Or you could email customer service of
Jun 15, 2008 | Vev Vigano Kontessa Oro 12-Cup Espresso...
Vev Vigano Kontessa Inox 6-Cup Espresso Machine Logo
349 people viewed this question
Top Vev Vigano Coffee Makers & Espresso Machines Experts
ray gallant
Mister Danger
Are you a Vev Vigano Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
