Question about Sony VAIO VGN-FJ270/B Notebook
Sony Vaio VGN-FJ170 - fan makes loud noise then stops
My fan is making this laud helicopter noise then it stops. I just restarted and now the fan is not on at all. the replacement fan is $120 plus shipping.
Is it going to help if I disassemble and clean with compressed air from the can? how do I do that? Do i unscrew the bottom cover or do I pop off the keyboard.
thanks
  • mdelaet May 26, 2008
    I have the same problem and have tried to open the case. However it just seems to remain stuck around the dvd drive. I removed all screws on the bottom, but what am I missing?
  • Anonymous Jun 09, 2008
    Can't open it either. Trying to get a manual.
I have this laptop to, I disarmed totally, do screws from bottom then take out keybord it has some pins facing the screen side with a little flat screwdriver you move them, then one screw holds the DVD unit, then do all screws around the keyboard, to open the case on the battery you have like other clips, from the is pretty straigth foward, CMOS battery is near the ram area and it orther to get to it you need to undo the screws on the motherboard. Also had some problems with the windows not restaring and the problem was one the rams broke or get damaged and always go to recovery and then blue screen.
!The most important the fan problem is that need a BIOS updated, you go to sony, vio model and look for the driver is the version R0140X6 here is the link http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FJ170 I hope this little guide work and good luck.
Posted on Dec 31, 2009
I have the same problem, so i disassembly it completely, but now i power it on and the lights power on, but the computer wont boot, nothing appears on the screen, and i cant find where is the bios to restore it
any suggestions?
Posted on Aug 26, 2008
My vaio's fan cuts on and off continuously. The noise is coming from the rear left. Any suggestions?
Posted on Aug 09, 2008
There's a screw beneath the keyboard that locks the dvd player in. Pop out the keyboard by pulling up from the top lightly while pressing down the four clips that hold it in place at the top near esc, F5, F11, and insert. You should be able to get into it from there.
Posted on Jul 05, 2008
Prhps varungrover cood offr lik sum hlp nsted. a lnk 2 srvce mnual wood b cool. huh huh.
Posted on May 26, 2008
    Champion:
  • 207 Answers
Bottom cover u can do it evn if u dont have the can u can use hair dryer moreover do grease it lil bit by some some gud luricants make sure u dont drip it on brd
Posted on May 22, 2008
My laptop fan is making big noises ,my laptop model is sony vaio vgn-cs190,what should i do replace it or any suggestions.please let me know
If it sounds like a plastic helicopter, them you have a problem with the heat (which probably melted the area around the fan, not the fan itself) that comes from leaving it on a non-hard surface. You should never have it on a bed or blanket or carpet for more than 10 min. But anyways, you will either want to take it to a repair shop (don't let them **** you around though, make sure THEY know that YOU know that it's only 15 minutes of work to fix) or you can go buy a new one. I had the same problem with a Compaq that had dual processors. I could practically cook an egg with it, but i actually ended up having to cut and reshape the ports for the heat to escape better (and to make the helicopter noise stop). So if you have ANY know-how at all and can do it yourself, or you husband, son, wife maybe? just guessing here... Anyway what i was trying to say is it would be about 10 times cheaper to have someone fix it unprofessionally. But that is only if it's making the helicopter noise. I really should have had you clarify before i started typing i guess.
Feb 15, 2011 | Sony VAIO CS Series Notebook PC...
Function key doesn't work, how to fix it?
Install VAIO Event Services (Notebook Utility) and restart the Computer.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170B&upd_id=2002&os_id=7
Jun 25, 2010 | Sony VAIO VGN-FJ170/B Notebook
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Nov 10, 2009 | Sony VAIO VGN-N130G/W Notebook
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Oct 15, 2009 | Sony VAIO VGN-CS118E/P NoteBook
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
Sep 23, 2009 | Sony VAIO VGN-FJ170/B Notebook
Sony Vaio VGN-FJ170 USB Ports do not work.
are all your drivers updated?
and all your windows updates are done
hope i was helpfull
good luck
Mar 18, 2009 | Sony VAIO VGN-FJ170/B Notebook
Sony vgn-fj170 labtop and my fn button is not working
I suggest that you install the Sony Shared Library first and then install the following drivers & software to resolve the issue. I have provided a link* to download and isntall the drivers & software: Sony Shared Library for Microsoft Windows XP: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1846&os_id=7 Sony Notebook Utilities: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=2002&os_id=7 Sony Notebook Control Device Driver: http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170&upd_id=1775&os_id=7
Feb 14, 2009 | Sony VAIO VGN-FJ170/B Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
3,261 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
