Question about Panasonic PT-47WX42 47" Rear Projection Television
Panasonic pt 47wx42
It blinks 3 times
  • 3 more comments
  • cherriez001 Jun 27, 2008
    My tv does the same thing. I turned it on and the picture came up for a brief second. Then it turned itself off and the red power light blinked three times consecutively and the picture was not regained.
    Do i also need to change out the convergence ICs?
  • harbo Aug 07, 2008
    i have the same thing. power light flashes 3 times...no picture. is the convergence part STK392-110 my solution?
  • deals4less0 Dec 21, 2008
    I have the same problem. My projection tv powers up for 1 second and it powers down. it will not re-powerhen the stand by light blinks 3 times consecutively.
    Any soluions?
  • paintingsplu Dec 27, 2008
    I had the same problem. I replaced the convergence IC's and now the set powers up, shows a purple screen with wavy white lines and shuts down after a minute or so. Either I did something wrong on the repair, or screwed up something else in the process.
  • Dr JayS Dec 29, 2008
    Same, Same, Powers up for a second, with picture, then goes out and the LED blinks 3 times. If i unplug it and then plug it in again, it will start up again for a second than blank out and give me the 3 blink. It started after a power outage! Turning it off is not enough, it needs to be unplugged--I have discovered!
  • Panasonic Master
  • 8,617 Answers
Youre convergence ICs need to be replaced. there are two of them they are STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the repair yourself. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 20, 2008
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Power Supply Problem with Panasonic #PT-47WX42.
usually the standby power is at fault if the led doesnt come on. Heres a link where you can get the service manual and if you purchase the manual they email it and provide unlimited free support to help you test and diagnose the set and help by locating parts as well. Heres the link if youre interested.
Posted on Mar 24, 2008
asnowman
  • 788 Answers
SOURCE: I have a problem with my Tv pt-47wx42
Your symptoms sounds like a damaged convergence IC.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes. If it is like you described and it is in the top and bottom, you may have a problem in the top and bottom pincushion circuit.
You stated that the charge will be $80.00 to diagnose this problem, I would ask if the diagnostic applies to the repair, if you choose to repair the set.
I have seen this type of repair run from $250.00 - $350.00.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon and it should only add the cost of the part to the repair.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 07, 2009
SD Tech
  • 14553 Answers
SOURCE: panasonic PT-47WX42 blue horizontal convergence failed
Picture you submitted with this is Toshiba--if set is Panasonic pt47wx42 it uses two STK-392-110 CONVERGENCE IC'S----both need to be replaced and any of the blue 2.2 ohm resistors around them that are bad changed also--the resistors are light blue in color--if you locate them look for any that are white in the middle. The convergence chips are on metal heat sinks next to each other and are black(about 2 inch wide and 1 1/2 inch tall). They will have the STK-392-110 number printed on them in white.
You can buy both chips on Ebay for less than 20 dollars including shipping. I have step by step instructions for this repair on this kind of set--if you have the skill you can do it yourself.
Most of these sets just need the two chips changed and the set adjusted. If you cannot do the repair yourself--now is the slow time of year for TV shops--shop around--I do this kind of repair in the home--takes about an hour--shops will try to charge 300-400 for this and I do it for 200-250----I have done hundreds of these sets in the last year.
If someone wants to "take it to shop" keep looking; any good tech can fix this in your home; once the chips are replaced they will be good for about 5 years--some go 8 years.
If you want the instructions let me know and give me an email address and I will send them to you---If you have the skill you can do it yourself--
You did not ask---the reason they fail is there is a white heat sink grease applied to each of them when they are installed--it transfers heat from the chip to the metal quickly--after several years it dries out from the heat and the chip reaches a point where it cannot move the heat fast enough--it then fails.
I do this here for free and if this has been helpful give me a vote here--IF you have any questions or want to have the instructions reply to this here--The instructions are my own--they are in Microsoft word.
Regards, SD TECH
Posted on Aug 31, 2009
SD Tech
  • 14553 Answers
SOURCE: panasonic pt-47wx42 5 blinking power
5 blinks is short protection, it means a short on the 140 volt line coming from the set's power supply.
Most likely is the horizontal output transistor is bad.
Let me know if you want to know how to get at it and test it.
The set has a light box that contains everything that can be removed for this kind of service.
I am very familiar with this set and have fixed hundreds of them.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
If you have questions post a comment here and I will assist you.
SD TECH
Posted on Sep 14, 2010
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
I have a Panasonic PT-47WX42 .. porew light flashes 3 times the stops,, then repeats..if I unplug the power cord then turn on the tv. it warmsup the picture comes on for maybe 3 sec then hear a click just...
The 3 blinks is indicating the set has shut down due to the convergence circuits. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Jul 28, 2011 | Panasonic PT-47WX42 47" Rear Projection...
I have a panasonic pt-47wx42 projection monitor. It will not turn on and the red light next to the power button blinks three times
The 3 blink error is caused by failed convergence ICs and the six 2.2 ohm resistors. Installing the convergence repair kit for your model should solve the issue. The kit is available from www.tvrepairworld.com the kit contains the 2 ICs with heat sink paste, the 6 resistors and the cd with instructions
Jul 11, 2011 | Panasonic PT-51HX42 51" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Power light blinks 6 times
1. What is your resolution setting?
2. Sometimes that your resolution might be set to high. Adjust the resolution and see if this corrects the problem.
3. If not then you might have a problem with the power supply might be shot and repaired.
Sep 07, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Power blinks 3 times, no pic, no sound
Yes 3 blinks means convergence, and yes they are both STK392-110 you can get replacement ICs at the following link with free installation instructions with pictures.
Aug 19, 2008 | Panasonic PT-47WX42 47" Rear Projection...
47wx42f panasonic tv
Does the led blink when you press power? If so please let me know the number of blinks as that is an error code.
May 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic HDTV Projection PT-47WX42F won't turn on
Your Set is going into shutdown mode due to the convergence section of your television. Thats what 3 blinks mean. It could be just the Convergence ICs and resistors or you may need a new Signal board TNP2AH035 Let Me know if you need further assistance with this problem.
Feb 16, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
