Question about WYSE S10 (90210501) Network Terminal
RDP Session Freezes randomly
We have about 70 S10 clients in our network and have 2 Terminal Servers in place. For about 2-3 months users suffer from frozen rdp sessions. The machine freezes I am just able to move the mouse pointer but not able to give commands by clicking. When I check the user's session from Terminal Server I find out that the session is disappeared. The only way to recover from this problem is to hold down the power button until it restarts. This is very annoying cuz in the end user may loose unsaved data/files etc. Do any of you have the same problem? Any solution? Thanks in advance.
REgards.
Sedat
  • Anonymous Jun 10, 2008
    I have 3 that do exactly the same thing and it is very annoying. I so far have not been able to find any reasonable cause or solution to this.
  • Anonymous Mar 31, 2009
    Yes semms to happen same time of day for a period i am looking at some sort of net work protocl DHCP etc. It is like the box locks its vidio buffer.
What an idiot
Posted on Jul 01, 2008
    Problem Solver:
  • 9 Answers
Probably a virius
Posted on May 20, 2008
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
I am unable to on my thin client it is based on windows server
check your server RDP policy in terminal server configuration,double click RDP permission tab,add user everyone,set full permission.
Nov 13, 2009 | HP Compaq Thin Client T5300 (dc643a#aba)...
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Connection Problems
W2000 Terminal Server used to corrupt the accounts of RDP users every now & again. Wouldn't surprise me if W2003 did the same thing :{ I used to create a copy of the user's account on the server (with an incrementing number on the end of the account name) & change the default account in TS management to that new one when this sort of problem occurred. I then made a copy of the new account & deleted the corrupt one.
Of course there are all sorts of other reasons this may happen but that may take a fair bit of hands-on investigation to sort.
For info on what's actually happening: Have you looked in the TS logs? Or the System and Application logs? Have you looked ta the logs in the client? Can you connect to the same TS server & account using a PC & the MS RDP client? If not, try the solution above :)
Dec 27, 2007 | Compaq Evo T20 Network Terminal
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
WYSE S10 (90210501) Network Terminal Logo
1,159 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
