Question about Sharp AR-BC260 Color Copier
Black Lines Sharp AR-BC260 copier printing black lines across paper.  These lines started periodically printing out towards the bottom of paper. Sometimes faint and other times dark.  Lines now print out any where from middle of page on down and extremely often. I have cleaned the glass, but lines still appear.
  • 2 more comments
  • GilaMonster May 21, 2008
    The black lines do show up on both. But not real keen on terminology of all the parts. Need it in Mickey Mouse terms please. I know what the drum is, and have heard of the blade....but what is the ufr?  And is there any way to pin point which part is needed, or is it better to replace all at same time?
  • GilaMonster May 22, 2008
    Yes, a copy repair person definitely sounds like a good idea at this point.  Thank you much for your assistance.
  • Anonymous Mar 26, 2014
    i have random black lines throughout the print, getting worse with each page
  • Anonymous Mar 29, 2014
    I have a XE Series Xerox B & W copier where copies are coming out with dark black lines through one side of the paper. Is it the drum that needs replacing?
If the lines its an interval o 3 marks from trail edge to end edge maybe its a gear to move toner cartridge that gears its cracker check this and remplace good luck!!
Posted on Jul 31, 2010
  • Jason Mgbi Aug 02, 2013
    Please explain this further.
  • Sharp Expert
  • 1,326 Answers
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
  • Chris Coughlin
    Chris Coughlin May 22, 2008
    A "ufr " is a Upper fixing roller. It is in the unit that gets HOT. Some times the coatting on the roller gets worn off from use. It can cause black lines on copies aswell as the drum and blade. I take it that the fix was not just cleaning both glass's. You may be int more then just Mickey Mouse terms.... You may have to get a estament from your friendly copier repair person...Good Luck..... Just to let you know the drum is going to be the most coastly part of your adventure.
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR BC260 color printing Lots of ghost lines in color prints
depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Nov 19, 2008 | Sharp AR-BC260 Color Copier
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp ar-bc260
change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
May 16, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
428 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
