Question about HP Photosmart M425 Digital Camera
On-off button cant get my camara to turn on...the button is stuck
  • amadee Nov 01, 2008
    same problem!
The clip that holds the on/off buton in place has cracked. you will need to take that case apart which means removing several tiny screws (about 10) and removing the broken on/off button. you can drill a small hole (3/16") thru the case that will allow you to operate the on/off buttn by poking a pencil thru the hole. then reassemble the camera. this may be more trouble than the $40 dollars it would take to replace the camera. y could try to drill the hole without opening the camera and hope for the best. you will need to drill the hole at the bottom edge of the slash between the on and off printed bellow the power button (ON/OFF)........good luck
Posted on Nov 30, 2008
Black camara screen
What is the make and model of your camera, not enough info to suggest any kind of solution.
Dec 14, 2013 | Cameras
Nokia n73 main camara start when switch on the
Your Cassing Back Cover doesn't deactivate the button. And also your side button is stuck ot PUSHED. Please chagne the cassing and also clean the Button.
May 18, 2010 | Nokia N73 Cellular Phone
Dropped the camara,it turns on & everything works EXEPT capture button
Unfortunately, as you have found, the cost to repair these cameras is usually not viable, as it is cheaper to replace the camera.
Even if it is repaired, often the impact from being dropped can cause small fractures in boards or loosen the optics and while they may work ok now, can continually develop faults later.
My advice would be to replace the camera, as you will also get a new warranty as well.
Mar 24, 2008 | Kodak EasyShare V603 Digital Camera
Fuji FinePix F470 Digital
Try another battery, it's possible current battery no longer viable or needs a deep discharge recharging.
Dec 27, 2007 | Fuji FinePix F470 Digital Camera
Camara
use the button on the right side of the phone, press it and wait about 3 seconds. the camera should turn on.
Dec 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do you take a picture
Does anything happen when you press the snapshot button (not the video record button)? If not, you might have a defective camera.
Dec 12, 2007 | Aiptek MPVR Digital Camera
Fuji Fine pix F470 digital
Shoot, I have the same problem and posted the identical question along with this one. I'll respond her if I hear anything.
Nov 24, 2007 | Fuji FinePix F470 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
HP Photosmart M425 Digital Camera Logo
97 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
