Question about Zebra Z4M Printer
Zebra 4M Plus
Prints barcode and text but does not print graphic of logo. I have tested with jpg, bmp, tif and pcx. Can you assist?
  • 155 Answers
What software are using? If you use or Zebra Designer Label Matrix, uses its own drivers. If you use another driver, verify that the graphics option is "dithering".
Roberto Martinez
Posted on Oct 06, 2009
Zebra LP 2824 not printing a barcode
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Aug 19, 2010 | Zebra Eltron LP 2824 Thermal Printer
We can't get our Zebra TLP2844 to print on the left matgin. It only prints in the middle of the label, which messes up the barcode. Our IT Dept has the manual and they can't seem to fix it. It was working...
reset the printer to factory defult ( from the driver( download segull driver) www.seagullscientific.com
check if the driver that you using have the correct Length and the With from the labels that you use.
Print a test page (should come with windows logo plus the text in all label. clean the printhead.
Aug 18, 2010 | Zebra LP 2844 Thermal Printer
I would like to have a directional arrow print on the label at the end of the text
This is usually done by adding a graphic file (.jpg or .pcx) of an arrow to your label design software.
Apr 26, 2010 | Zebra 105Se Thermal Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Zebra 4M Plus printer keeps printing same label
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Zebra Z4M Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
Zebra Z4M Communication
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 27, 2009 | Zebra Z4M Printer
Print Graphic by coding program to Zebra printer
no u cant use jpeg... u can use .bmp "Monochrome Bitmap (*.bmp,*.dlib)"
Aug 15, 2008 | Zebra Z4M Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Z4M Printer Logo
470 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
