Question about Tomtom GPS
We have a tomtom GO 510, that we purchased on May 18, 2007. We have used this for the past year, today we tried to enter a trip route into it. We turned it on but nothing cam up, and now we can not turn if off we just have a blank screeen
DO A HARD RESET ON THE UNIT FIRST. IT IS HARD TO SEE AND VERY SMALL, BUT IN THE TOP OF THE BACK OF THE UNIT WHERE IT HOOKS INTO THE CRADLE THERE IS A RESET HOLE. AS YOU ARE LOOKING AT THE GREEN CIRCUIT BOARD BY THE CRADLE CONNECTOR, LOOK AT THE PLASTIC PIECE, NOT THE PIN CONNECTOR BUT ABOVE IT, ON THE RIGHT SIDE. THERE IS A VERY SMALL HOLE AND THE PLASTIC PIECE IS SHAPED TO GO AROUND IT FROM AN OTHERWISE STRAIGHT EDGE. YOU WILL NEED SOMETHING SMALL, I USED A BENT STAPLE, AND PUSH IT IN THERE FAIRLY FIRMLY. IF THE UNIT IS ON, IT WILL SHUT IT OFF. WAIT 5 SECONDS AND TRY TO TURN ON AGAIN. WIRKED FOR ME. GOOD LUCK!
Posted on May 21, 2008
Iwant to download truck routes to my tom tom 510
Just go to the tomtom website (see below), and find the desired map (update) for your device.
https://tomtom.com/en_gb/sat-nav/maps-services/shop/travel-map/
Dec 31, 2015 | Tomtom GO 510 Car GPS Receiver
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
My go 510 is about 1 year old and it was working
try resetbutton, go tomtom.com, sel support, search reset, sel softreset sel device, do as told. goodluck
Feb 13, 2010 | Tomtom GO 510 GPS Receiver
Instead of addresses can I set the gps to highway numbers as (Route 39).
Hi yes you can but with GPS units its kinda funky for example on my TOMTOM I have to enter US route 59. On my wife's Garmin you have to enter it as Illinois state route 59 and on my moms Magellan it goes in completely different.
Most destinations and even points of interest can be found but it often takes as long as 5 minutes to figure out how to input the info.
An example for instance in my area I have looked up Fox Valley Mall but on Magellans unit it only shows up as Westfield Fox valley, I have lived here 20 years where did the Westfield come from?
Something I have done in the past is select "find intersection" and then enter a street that I know intersects with the Highway I am looking for and then check to see how the GPS recognizes it.
Hope that helps
Jan 03, 2010 | Tomtom ONE GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
I live in Michigan and set up my tomtom. I'll be going on a trip to canada in a few weeks and wanted to see how it worked. When I try to set up a route from home to the hotel where I'll be staying in...
By default, the TomTom ONE 125 does not include maps of Canada. You can do one of two things:
1. If you just purchased it and can take it back, buy a TomTom ONE 130. It includes Canada maps and usually is only about $10-20 more.
2. Use the TomTom Home software (the same one that you use to update the TomTom and add voices, etc) and purchase the maps for it. I'm not sure how much they are, but certainly less than a new GPS.
Hope this helps!
May 17, 2009 | Tomtom ONE 125 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
GPS Logo
47 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
