Question about Sony Handycam CCD-TRV68 Camcorder
Sony Video 8 TRV30E Handycam keeps ejecting tapes
I have a Sony Video 8 TRV30E that everytime I insert a tape and close the door, it does a whiring sound and then ejects the tape. I've tried several tapes and the same thing happens. The tapes seem okay each time so at least the camera is not chewing them up
  • pounder40 Sep 16, 2008
    I read somewhere else to give it a few gentle whacks so I tried it and it worked. Thanks anyway for your reply. The camera had not been turned on for a while so that's maybe that's why the problem occurred. It works perfectly now.
    Novelist:
    Scholar:
  • 64 Answers
The real reason this is happening is the spinning heads can not equalise, either with a preset speed or match the speed of the recorded media and so it ejects the tape as being incompatible.
DO NOT SMACK IT.
As I have done this in frustration and to just get the camera working, the mechanism inside these Sony cameras is so delicate and on such a soft-metal base plate, that the plate bends and is likely to be the cause of the problem in the first place (a small knock in the bag etc - you know where it says on the tape cover to 'press here' and in the instructions it says "do not press elsewhere on the cover" thats why, it's delicate).
Before you damage that camera and loose the ability to adjust/correct the speed of the heads all together, I would strongly suggest you take it in for repairs to a very reputable technician.
NOTE:: If your speed is wrong now and it is fixed, all that you have taped on the wrong speed may not be playable when you get it back - backup/copy all your compact (8mm) tapes to your computer/DVD/VHS anything.
You rated one off-the-cuff response - I hope you find it good to rate mine and I'd really like to here how you went. Please post a comment here so we know you're good.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 06, 2009
  • Isaac Turner
    Isaac Turner Jul 02, 2017
    Given that the camera is over a decade old, where would one find a qualified repair man without searching a cemetery?
I was having the same problem. I just gave it a few gentle smacks from every angle possible and it quit acting up.
Posted on Sep 16, 2008
    Sergeant:
    Champion:
  • 319 Answers
Unit has loader problems, have it serviced
Posted on Aug 14, 2008
  • jonny8 Mar 28, 2011
    My Hi8 analogue camcorder was stuck in the eject position. I was going to purchase another second hand one so that I can copy the old tapes on to digital; then I saw these posts. I certainly wasn't going to pay for a service, so I tried a few light whacks, as suggested. My wife later told me she thought I was losing it. Hitting the old TV might have worked, but not modern electronic equipment. But it worked! The camcorder works fine.
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
2,016 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
