Question about Kensington PilotBoard 64385
"page down" lock light on keyboard..don't know how to unlock (?)
I have a Kensington keyboard at work. Somehow (by hitting some random buttom I'm sure) I've locked the "page down" function (third light above 10 key pad). Can anyway tell me how to clear this? Thank you in advance!!
Scroll Lock button. =]
Posted on Dec 02, 2008
SOURCE:
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
How to function Fn
Step 1:
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key. The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function. The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop. Use the drop-down menus on the support page to choose the specific product line and then model of your laptop. Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys. Find the sequence of keys you need to press to unlock the function key on your laptop. Press and hold the function key on the keyboard and then press the other keys required to unlock it. Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys. Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
b>
Feb 15, 2013 | Gateway NV52L06u Laptop PC
What is the third lock light, I have a Cap Lock, a Numerical Lock. What is the third one?
I beleive it is the scroll light:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F3 Keyboard light down
Fn+F4 Keyboard light up
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Num Lk: Scroll Lock on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear
Fn+C Splendid
Fn+V: Life Frame
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 20, 2011 | ASUS 90-A4C1K1000 Keyboard
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
My mouse pad itsnt working.. wondering if there is a lock on it!
On some laptops, there is a button that is used to disable the mousepad.  Sometimes it is a small button just above the mouse pad that has a light next to it.  Normally when it is off, the light is either red or amber colored.  There is almost sometimes a function button to toggle the mouse pad on and off.  It is normally one of the "f" keys above the numbers on the keyboard, and should have a picture on it of a mouse.  Then there is usually a FN key in the lower left corner of the keyboard.  You have to hold that down, and press the "f" key at the top of the keyboard that has a picture of a mouse on it at the same time.
Mar 30, 2009 | Acer Aspire 5610 Notebook
I was getting Microsoft to help me With another problem and they got on my computer distantly. When they were done, the keys that can be used for a number pad were locked on. the only way to use these keys...
there's a number lock on the upper right side of your keyboard, above the number pad..and a light above it to indicate when it's on..just press that key, and you should be ok..
Apr 30, 2008 | Computers & Internet
Function keys not working
try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard. Most laptops have a light that will turn on and off when you do this, indicationg that the funtion keys are in use. depends on the brand
Oct 24, 2007 | Computers & Internet
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Kensington PilotBoard 64385 Logo
3,293 people viewed this question
Top Kensington Computers & Internet Experts
Alun Cox
robert roberts
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
