Question about Panasonic Pro NE1257 Microwave Oven
Microwave panasonic in demonstrateion mode and won't heat remove from lthis mode
Won't heat is in demonstration mode
  • Panasonic Master
  • 9,098 Answers
First try hitting the Clock pad three times.
Or if it has a Function pad, hit that, then follow the prompts. On some models, it's Function > 0 > 2.
If this is a model NE1257 (the model under which you posted) then it doesn't have a Function pad.
If none of this works, I'd suggest unplugging it for a few seconds or so, then trying again.
If none of this works, then please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
Just unplug and replug
hopr that helps
Posted on May 09, 2011
I have no problem but can you explain micropower
Posted on May 01, 2010
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
My microwave doesn't heat up everything else seems to work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';
Sep 14, 2011 | Samsung SMH8165STE Microwave Oven
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
Feb 01, 2011 | Samsung SMH9151 Microwave Oven
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
Timer runs extra fast and microwave does not heat
I had this same problem with my Maytag Microwave. Unplug the unit and plug it back in. It fixed my issue.
Sep 04, 2009 | Maytag Microwave Ovens
Samsung Microwave runs won't heat
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 07, 2009 | Samsung SMH7174BC Microwave Oven
Get out of demonstration mode
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2008 | GE XL1800 1100 Watts Microwave Oven
Panasonic Pro NE1257 Microwave Oven Logo
448 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
