Question about GoVideo VR3845 DVD Recorder/VCR
VR3930 {VCR SOUND .}
VCR REPLAY .LEFT CHANNEL SOUND IS DISTORTED AND LOUD.RIGHT
CHANNEL IS OK BUT SEEMS LOW VALUME
  • 2 more comments
  • neumanngo2 May 20, 2008
    I have tried almost everything from using new wires,cleaning the playhead checking for loose wires ect.Discovered the problem about 3 weeks ago.Tried many things but so far no improvement.I noticed when play mode is selected sound is ok for 3to 4 seconds then distorts.
    Sound problem only exists in Vcr mode .Out put from Dvd channel is ok .This would indicate
    external wiring is ok?
    If have tried cleaning tape, also opened the unit and tried head cleaner without positive results.
    Tried several casettes .All do the same thing.
    President:
  • 2,712 Answers
Try using a different set of cables. If that does not work, try an alternative input. For example, if you are using RCA plugs, try using Scart cable instead and see. If it works, it could indicate a fault with the RCA output board in your VCR.
Does this only happen in the VCR, or even when you watch regular TV?
Posted on May 20, 2008
  • Swilin Sampson
    Swilin Sampson May 20, 2008
    Does this occur with all VCR cassettes? It could be specific to the cassette you were trying..
  • Swilin Sampson
    It looks like an internal audio problem with the VCR. You may want to get it serviced (or replaced if under warranty)..
  • 3,037 Answers
What kind of connection are you running into this vcr? Have you tried a different vcr which would test to see if it is the cables or the vcr. How long have you had this and is there any reason that you know of that might have caused this, please get back to me on this.
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    you probably have a loose connection in the audio circuitry within the player. check for cracked connections and follow the audio from the input. This happens on all inputs correct? Antenna, dish, videotape, etc?
  • Benjamin Patri
    yes, external wiring would be ok, have you tried a cleaning tape in the machine at all, you can buy this at any basic electronics store or Best Buy, Circuit City, or even Walmart
  • 149 Answers
Double check your connections especially scart ones. make sure no pins are bent or touching.
how long has it been like it.
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Whent turn up the valume sound whit no power
I would contact Adcom for a service place near you
Feb 17, 2010 | Adcom GFA-5400 2-Channel Amplifier
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Distorted sound
This is an automatic high end amp. Make sure you are using 8 ohm speakers. If the connections are correct, also use good quality speaker wire.
If this makes no difference, it seems that it would need to go to the repair shop.
Feb 18, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
GoVideo VR3845 DVD Recorder/VCR Logo
41 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
